New 5083e, 553, and MX10 delivered!
   / New 5083e, 553, and MX10 delivered! #22
Do you happen to have a photo of your toolbox setup and location? I would like to mount one on my 5520 but am not sure exactly where they put it.
Other than the ones posted above here are two others. Ill try to take closer pics next time I'm at our land.
By the way I got my first couple hours of seat time in the new rig this afternoon. Spent it moving the shed to a better location. Still temporary but better. Managed to get one of the rear tires off the ground for a second. Yikes! I wasn't being careful and I was trying to lift and pull the corner of the shed sideways with the loader. It probably felt worse than it actually was but still. Live and learn.
   / New 5083e, 553, and MX10 delivered! #25
I was going to move my shed at one time but didn't have to after all. I hadn't decided if I was gonna pull in reverse, or hook some chains up to the 3 point rocker arms and pull in forward. I do know if you are ever gonna lift so much your rear end comes up (even with a 6' bush hog)(which I've done a handful of times), you better make sure your front tires are aired up near the max if you have it in 4WD. I learned this lesson at a young tractor age. Actually I was about 44 but I was moving big loads of wet dirt and I spun the rim right out of the bead backing up too fast. $75 mistake.
   / New 5083e, 553, and MX10 delivered! #27
enjoy that new tractor an time spent with your kids.
   / New 5083e, 553, and MX10 delivered! #28
I've got a 5105M and wish I had the option of a buddy seat!
   / New 5083e, 553, and MX10 delivered! #30
Where does the toolbox bracket bolt to the frame? That would be enough info and a picture, or description would help.
Toro Mower (A50324)
Toro Mower (A50324)
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Toro Workman Utility Cart (A51694)
Toro Workman...
