3320 Cab height with R4's
   / 3320 Cab height with R4's
I have 94.25" from floor to the top seal
I sure hope so cause it would sure be tough letting the air out of the tires every time I need to put it in the garage :laughing:
   / 3320 Cab height with R4's #14
You need a backhoe. My backhoe drops the tractor almost 2". Tell your wife its either a backhoe or a major refit to the garage...:laughing:
Hmmmm.....just may try that.....:thumbsup:
   / 3320 Cab height with R4's #16
Haven't checked lately but there were two sizes of R4 tires offered with the 3X20 when I ordered my 3720 cab tractor. I chose the smaller size just so it would fit in the garage doorway. I'm sure the smaller tires will work for you ........... don't know about the larger R4 tires.
   / 3320 Cab height with R4's #17
Mine's in the shop now, so I can't measure. The 3x20 series offers two different R4s.
(a) four ply; 27x8.50-15 front, 43x16.00-20 rear
(b) six ply; 25x8.50-14 front, 15-19.5 rear
Given those numbers, the 4-ply R4s should make the 3x20 cab model a little taller than the heavier duty 6-ply option.
//greg//
   / 3320 Cab height with R4's #18
This is more info to add to my note above. Distance from floor to top of cab roof is 88.5 inches. My 3720 has the Galaxy R4 6-ply tires.
Rear: 15-19.5 Front: 25x8.50-14
I wonder how much difference there is in the smaller R4's compared to the larger R4's....
   / 3320 Cab height with R4's #20
According to the Galaxy website ATG - Alliance Tire Group here are the differences in rear tire sizes.
15-19.5 ===> 40.0 inches O.D.
43x16.00-20 ===> 42.6 inches O.D. (tractor height will be half difference or 1.3 inch higher)
2016 Deere 180G (A60462)
2016 Deere 180G...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56438)
Koyker Loader...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
