Fuel Tank Vacuum
   / Fuel Tank Vacuum #11
   / Fuel Tank Vacuum #12
I do believe you will find that there is preasure in the tank not a vacuum. The carbon canister on gas units vents the tank into the air inlet. Part of the emission tests for a gas unit is the checking of the cap to be sure it holds the proper preasure.
Just a thought!
   / Fuel Tank Vacuum
My vent is in the tank's cap.
Thanks --- I see it. I'll check my cap to see if it's the same ---- on my cap, that disk that has the vent hole in it will freely fall out of the cap. Is yours the same?
   / Fuel Tank Vacuum #14
It's in there tight. I don't see coming out unless the cap was broken in 1/2
   / Fuel Tank Vacuum
OK --- I took that disk with the vent out of my cap. It looks like yours definitely has a pin hole in the center of that soft, flexible membrane that's dead center of the disk. Mine has no such pin hole --- it's a solid, soft flexible membrane. Maybe that's my problem ---- picture below without the cap.DSC00184.jpg
   / Fuel Tank Vacuum
Lousy pic --- hopefully, this one is better.
   / Fuel Tank Vacuum #17
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317206"/>
When you look into the center of the disk on mine, that light colored gray is a spring.
   / Fuel Tank Vacuum
So, there's no pin hole in that membrane?? I could swear that I see a pin hole in that first pic that you posted --- And, I agree --- the light colored gray around the outside edge looks like a spring to me too.
   / Fuel Tank Vacuum #19
Typically the vent is in the cap. If not there is another opening somewhere on the tank but since the cap is on top and there is a already a hole in the tank there, the cap is the easiest place to put it.
   / Fuel Tank Vacuum #20
Running a vacuum reduces foaming for diesels with return lines from the injector pump to the tank.
UNUSED FUTURE FT-SCW46 STEERABLE COMPACTING WHEEL (A51248)
UNUSED FUTURE...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Alliance Flotation Tire (A50123)
Alliance Flotation...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
CATERPILLAR P5000-D WAREHOUSE FORKLIFT (A51246)
CATERPILLAR...
