Oil & Fuel Well I bought a MF 135 today
   / Well I bought a MF 135 today #41
I just did a head job on my Perkins gas, I recall some of the head studs for the lifting lugs did go into the coolant cavity but I don't recall the manifold studs doing this. I put anti seize on these only with no leaks. The others got sealant.
   / Well I bought a MF 135 today #42
G'day vegaome.
The stud is 5/16 unf on the manifold side and 5/16 unc on the engine side ,Going into the head.
I dont know what the hole will look like when you have finished removing the easyout so let me suggest a fix that I use with success every time first heat the easy out ,try to get it red hot with out to much heat on the head then when it is still hot use a Pin Punch and give it a tap in then try to work it out the opposite way ,once you remove the broken easyout and providing the hole you have drilled is near on centre of the broken stud ,using small drills and patience drill right through and keep increasing the size of the drill say one sixteenth at a time till you can see the old thread,when you are at this stage get an old Screwdriver a small one and grind the end into a small chisel,find the END of the thread and using the chisel gently ease out the old piece of stud thread Again with Patience the thread will come out like a spring if you are lucky ,once removed retap the hole using tapping compound just to get the best result you can .
If on the other hand when after removing the broken easyout the hole is to big you can tap it out to 3/8 "any thread but get a new stud first.
The other way is to drill and tap the hole out to either 1/4 npt or bsp Both are tapered threads ,install a Plug of the correct thread using loctite thread locker ,leave for 24 hours ,then either hacksaw or carefully grind the plug end till it is flush with the Exhaust surface on the head, mark your new hole using the new gasket as a guide and CAREFULLY drill a new hole ,try not go to deep and you will be back to new again.
just a word from my experience the word easy out tends to suggest that if one was to drill a hole and tap the EASYOUT in there all that is required is to undo the broken part ,definitly not so in fact the design of an easy out if you look at it when used it will EXPAND the thread and if anything make it even less likely to come out, My opinion on the spiral easyout if you have a set Give them to someone you dont like and buy the PROTO broken stud remover,it is tapered ,square in section with a sharpened leading edge ,it will come with user instructions.
So again Patience is the best tool to arm yourself with.
happy days.
Hutch.
   / Well I bought a MF 135 today #43
Are you sure, it may be 3/8 inch. Will be fine thread.
Thanks Zsink and Hutch,
I will try to work on it some more this week. I probably will have to go to 3/8. I don't have a garage or very many fancy tools. I can buy a tap and die though. Thank you for the input!
v/r
Mike
   / Well I bought a MF 135 today #45
Howdy Flusher,
I have never seen a perkins head apart. Do all the exhaust manifold studs thread into a water jacket? I have to tell you I was only in 1/2 inch if that and only went a little at a time. Thank you.
v/r
Mike
Don't know--never had the head off my Perkins diesel--but I saw some white smoke coming from the exhaust recently--probably a head gasket problem--so I'll be find out that answer when I fix that problem. The Hercules gas engine on my Minneapolis Moline BF tractor definitely has threaded through holes for the head bolts that penetrate the walls of the coolant galleries.
Howdy Flusher,
I wish you luck with your tractor. If you get a chance snap a picture. I hope I dont mess mine up to bad. I may get to work on it next week again.
v/r
Mike
Howdy Dieseltech,
I'm pretty sure its 5/16 inch. I need a good flat spot where I can tear it down.
v/r
Mike
   / Well I bought a MF 135 today #48
Howdy Flusher,
v/r
Mike
Thanks for the pictures. Can you take one of the head when you pull it?
v/r
Mike
   / Well I bought a MF 135 today #50
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2002 CLEMENT END DUMP TRAILER (A52472)
2002 CLEMENT END...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
