R1 Wide tires for CUT's
   / R1 Wide tires for CUT's #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I see a lot of utility size tractors available with R1W tires now, rather than just the narrower style R1's that have been around forever.
Are there any R1W choices for us guys with CUT's? I'd love to go with R1's for my tractor as I think I would gain a LOT more traction than my semi worn out R4's, but I would need to purchase all new rims for that. It would be nice if I could get an aftermarket, wider R1 that would fit the stock R4 rims. :confused3:
On a side note, I don't think I've ever typed so many "R's" before in so few sentences. :laughing:
   / R1 Wide tires for CUT's #2
If I'm not mistaken, I believe the W indicates an R1 tire with extra deep tread... not a wider tread pattern.
Oh okay, I guess that makes sense. I was under the impression that it meant the tire was actually wider, but after thinking about it, that doesn't really make sense (my impression) because they offer both R1 and R1W on the same rims with new tractors (at least I think so.).
Well, there goes that plan. :laughing:
   / R1 Wide tires for CUT's #4
That is correct. I think the "W" is for Wet. In addition to a wheel change you have to keep the same front to rear ratio if you have 4wd. R1 will give more traction than R4.
   / R1 Wide tires for CUT's #5
I think the W tires were made for rice and other submerged crops.
I have a helpful story here, I hope. The oem turf tires on my Case IH were on twenty inch rims, not twenty four like the Ag versions.
I wanted to go ag R1 and did, but it took a lot of studying to figure out the right conversion size. I wound up with pretty wide tires on the tractor which
are simply marvelous for traction and stability. And I made sure the tire height was within a tenth of an inch, so that worked out fine too.
BKT tires, largest tire mfg in India, had what I wanted, where there were few other options.
Daugen,
Did you have to buy new rims as well?
   / R1 Wide tires for CUT's #7
Here is a link to the John Deere sales manual explaining tires. R-1W is a tread between standard R-1 and the deep lug R-2 used for things like rice farming:
Understanding basic tire information
Here is a link to the European Goodyear tire book. If you look in the green bar at the top of each page, notice that nearly every one of their regular ag tires has R-1W tread, like it is their standard. Goodyear sold its ag tire business in North American to Titan but retains their own ag tires in Europe.
http://www.goodyear.eu/home_en/images/701_8044_GY_FarmRange_52pp_tcm67-9459.pdf
Looking through the Goodyear tires you will see R-1W in widths from the super narrow to super wide. Look at page 10 and notice they show their tires work out in ranges from very narrow to very wide all having the same rolling circumference meaning you can swap (of course you need different rims) without affecting the front/rear ratios.
   / R1 Wide tires for CUT's #8
Daugen,
no, which was a big savings; the challenge was finding a twenty inch diameter tire that had a sidewall large enough to make up the
overall height requirement.
   / R1 Wide tires for CUT's #9
My 4240 has 17.5L24 on the rear I was looking at tires one night and these popped up in the search on Titans site. They say they are a R4 but they have a R1 tread:confused3: They are a little pricey too.
Titanï½® Tire catalog
I just found these also.
Titan® Tire catalog
   / R1 Wide tires for CUT's #10
MHarry,
Thanks for the links, that is helpful information.
   / R1 Wide tires for CUT's #12
simply for comparison, my BKT rears were about 700 apiece.
Honda utv cart (A56859)
Honda utv cart...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
UNUSED DSBREAK DS140A HYD BREAKER W/ BIT (A60432)
UNUSED DSBREAK...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
Rooster Weathervane (A59231)
Rooster...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
