Hire someone to build, or do it myself?
   / Hire someone to build, or do it myself? #1
JDTank
Well, the time has come. I have put it off as long as I can.
I have been promising the wife horse shelters now for 2 years, and finally this summer, I have to pay up! Everyone who knows me refers to me as a mechanical genius. I can fix and operate anything. I grew up in a trucking atmosphere, hauling heavy equipment with my father. Also spent 6 years operating heavy equipment, and worked for some short line railways as a mechanic.
So, obviously, mechanics is fine for me. However, wood working, not so much. I have all the tools, no issue there, but I have never tackled building anything this big.
Has anyone here built horse shelters themselves? I am the type to do everything I can myself, for the sake of pride, it's cheaper, and I know it will be done right.
So, what do you think? Is it better to overpay someone to put up a small square structure? Or should I tackle this one on my own?
Thanks!
   / Hire someone to build, or do it myself? #2
Thanks!
JD,
I think you answered this one yourself :thumbsup:
   / Hire someone to build, or do it myself? #3
If you have the skills to do the work yourself, I would say "Go for it". Why not get a set of plans or make a set yourself, order all the material, and go from there? Please take your time and think one step ahead and you should be fine. If you have a friend to help you with the longer and heavier pieces, this will help considerably. best wishes.
   / Hire someone to build, or do it myself? #4
If you've no carpentry background you might be able to do it yourself.
Better yet thoroughly investigate what's available as kits or having a dedicated devoted (Amish or Mennonite) crew build it if they are available. Then take into account ALL the costs of materials if YOU bought them.
Some of the larger firms that put up lot's of sheds etc., and build DIY Kits, get material far below my cost at the BB stores.
There is nothing wrong in taking pride in the fact YOU earned the money that built the horse barn.
   / Hire someone to build, or do it myself? #5
If you're mechanically inclined then you should have no problem. Just watch a few videos on YouTube and you'll be a pro in no time..
   / Hire someone to build, or do it myself? #6
Around here I see that my neighbors are using metal carports and filling the sides in out of wood, it must work good because I see a lot of them. I personally do not have horses though.
John
   / Hire someone to build, or do it myself? #7
"So, what do you think? Is it better to overpay someone to put up a small square structure? Or should I tackle this one on my own?"
Why assume you will overpay? Do you get over paid for your work?
Another way of looking at this is, what else could you be doing with your time that would be profitable or useful, and you may enjoy the doing of, rather than spend time building the shelter? You have been shying away from the the shelter build for two years ... there is a reason for that. :)
   / Hire someone to build, or do it myself? #8
Although I think you should try to build it yourself..... Dave makes a REALLY good point. ;)
   / Hire someone to build, or do it myself? #9
Build IT!
If you have the time, Go to lowes or home depo an get a book on building. If you are able to use your hands go for it. Everything I have I have built, now I even saw my lumber on a saw mill I built!!!
   / Hire someone to build, or do it myself? #10
If you give us some idea of what you would like to end up with, size and dimensions, I,m sure you would get a lot of good advice on here on how to proceed. I,ve seen horse shelters that a very basic, with 3 sides and a roof, and some I wouldn,t mind living in, they were that nice. What are your plans ?
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
