Biggest Kubota L cab 4wd with 72" mmm
   / Biggest Kubota L cab 4wd with 72" mmm #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Need a tractor to do large scale semi-finish mowing in AC comfort. Also need to lift a 1000lb round bale with FEL and possibly pull a 10' hay rake.
Was looking at Used L 10 and 30 series Kubotas under $20k. There's quite a few available, but I don't know what the biggest one is you can buy and add a 72" mmm.
I know, why not a 3pt finish mower. It's not an option for this application.
Thanks.
   / Biggest Kubota L cab 4wd with 72" mmm #2
The L3940 is the largest tractor you can put a 6' mmm on. Philip.
   / Biggest Kubota L cab 4wd with 72" mmm #6
http://www.kubota.com/product/L60/documents/gl60_spec.pdf
It's got the mid-PTO, can't you put a MMM on it?
Just because it has the mid-pto does it mean that you can use a mmm. Mid-pto is also used for snow blower and broom. Look at the GL40 series, can only use mmm on the L3940 and smaller. In fact, if you look at the GL60 online brochure, they do not even list a mmm as an available implement at this time for any size tractor in that series. So right now, the answer is no. Philip.
   / Biggest Kubota L cab 4wd with 72" mmm #7
I think the guy was only curious. Sheesh
   / Biggest Kubota L cab 4wd with 72" mmm #9
This has caused confusion for as long as I can remember, Kubota even had a sales brochure out with a MMM on a 5740, but it was a misprint.
http://www.tractorbynet.com/forums/kubota-buying-pricing/259199-l5740.html
That is correct. It was a photo-shopped L5740 decal on a L3940 tractor. If you look closely at the grill size and opening, it is a L3940 for sure. Blame it on the Marketing people.
@ Lego StarWars Xbox guy. Not trying to be a smart butt, but if the guy was curious, I am sure he wants correct information. I am sure you would appreciate that too.
Philip.
   / Biggest Kubota L cab 4wd with 72" mmm #10
Since the OP asked about the GLxx10 and GLxx30 series for less than $20k I'm not sure if talking about the newer 40 series or brand new 60 series is going to help him much. I think you are going to be stuck with the 3830 and 3710 as the largest size. I remember a dealer telling me that the loader bracket for the 852, 853, and 854 is larger and interferes with the mmm. I think you would be best off trying to find one that already had the mower if possible.
2017 Ford Fusion S Sedan (A55853)
2017 Ford Fusion S...
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2008 TRANSCRAFT 48X102 FLATBED CHEMICAL TRAILER (A55745)
2008 TRANSCRAFT...
