Long road to home.
   / Long road to home. #201
Thanks Lee, great pics! I like the concrete post, how deep are they set?
Dave
Dave
The posts are down 40" with 10" thick footers below them. The total depth of the holes is around 50" below grade. By code I only needed a depth of 42", but wanted to get as much of the pole in the ground as I could, therefore the 50" hole depth. They are a good product, just expensive. In the long run they are worth it to me as I will never have to worry about one rotting off at grade level like wood will.
Dave,
I just went back through and found a close up picture of the lower portion of the poles on POST#135 if it helps.
Metal has arrived, thanks to my wife for the pictures.
   / Long road to home. #205
Lee, I think you are making great progress, although the videos showed some guy walking back and forth, back and forth, with often empty hands. :laughing: Putting the metal on will really make it look different.
That's funny. All the walking back and forth to get materials and put them together I wound up losing some extra pounds. Yay!
Ok, I promised some pictures of the stairs being built. My buddy didn't want his picture taken so I don't have any of the router jig he used. However I can tell you that it is a Porter-Cable STAIRS-EASE. They don't make them anymore from what he has told me. I did take some pictures of the assembly process today.
Here is what the stringers look like after we ran the router and jig. They are 2x12 Fir. This is a scrap piece that he wanted to test the jig's riser height on, as it is adjustable. That is why the risers and treads don't appear to meet, on the actual stringers they do.
The treads are 2x12 ripped down to 10 1/4" then slid into the appropriate slot. The next three pictures are of the back side of the stairs, as they are assembled face down.
The risers are made from 3/4" B/C plywood, again slid into appropriate slot.
Finished stair case.
The risers and treads are glued into place and screwed from the sides, three each end of the treads. The risers have two screws in each end and four along bottom edge to secure them to the tread below.
Feel free to ask if you have any questions.
   / Long road to home. #208
Nice job on your stairs, that should make for much stronger stairs, than cutting triangles out for the treds to set on.
Dave
Thanks Dave. They are the strongest stairs I have ever made/seen. We have been doing them this way for 20yrs. Have yet to find a better set of utility stairs out there.
I got out here on Wednesday, checked the metal. Half the roof was shipped red, not white. All the J-channel is white, not red. All added up about 1/3 the metal is wrong.
And then I got sick. Some nasty cold. Ashamed to say it laid me up for Wednesday and Thursday. I managed to crawl out of bed long enough to cut enough purlins for the trusses I have up. Got a few rows nailed down before I was spent. Jeez, I sound like an old man. Well anyway here's a picture.
Ok, no picture. I keep getting a "just crashed" message. Will try later.
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
