Male Skid Steer Plates
   / Male Skid Steer Plates
Thanks, Paul. I look forward to seeing your pictures.
Stuck
   / Male Skid Steer Plates #12
The ones on my Bobcats are about 12 inches wide, like these pictures found on google image search.
Here are mine.
Will have to measure the thickness, I'd guess at least 3/8.
Xfaxman,
Thank you! Your seperate receiver plates are the reason I need to know the exact width of the male plates. My pallet fork has a receiver that goes all the way across but, in the future, I might buy an attachment with plates like yours and I don't want my male ends too wide to fit. By the same token, I want them as wide as they need to be for sufficient strength.
Stuck
   / Male Skid Steer Plates #14
Bill,
That might be what I'll do. At this point, I have a pin on bucket and a set of pallet forks with a SS quick attach bracket. I've got to come up with a common hookup somehow or other.
I've seen some place that makes adapters for pin mounted attachments to a skid steer QA. Sorry I don't remember where, but they are out there if you are interested.
   / Male Skid Steer Plates #15
You could adapt one from an actual Bobcat. Any Bobcat bone yards near you?
   / Male Skid Steer Plates #16
Xfaxman,
Stuck
Most SSQA plates are open all the way across, that bucket I posted is the exception to the rule, but it shows what you are concerned about.
If you make the male ends no more than 12" wide, you should be okay. :thumbsup:
I edited that post, for clarification.
More pictures here: https://www.google.com/search?safe=off&hl=en&site=imghp&tbm=isch&source=hp&biw=1074&bih=788&q=SSQA+adapters&oq=SSQA+adapters&gs_l=img.12...5553.21403.0.24623.13.8.0.5.0.1.1130.4730.2j0j1j5-1j2j2.8.0...0.0.0..1ac.1.17.img.yKzz_tpu0QM
It's OK, I've found several adaptors. I'm just trying to figure the most practical thing to do in my particular situation.
Xfaxman,
Thank you for all the new pix. If most of the female plates go all the way across, I'm probably concerned over nothing important.
Stuck
   / Male Skid Steer Plates #20
Xfaxman's pictures explains it very well. Titan sells weld on plates complete with latch pins for I believe $279?? You will have to adapt them to fit your loader.You can find them on ebay. If you would like to do it the hard way (fun way), the pictures show what I did. I used half inch for the plates. The first attachment I made was a bale spear. Now I have to start working on the buckets. Dimensions are on the pics.
quick attach 005.jpgquick attach 007.jpgquick attach 008.jpgquick attach 009.jpgquick attach 003.jpgquick attach 001.jpgquick attach 002.jpg
8 Ft Fork Extensions (A50322)
8 Ft Fork...
Corn Reel (A50514)
Corn Reel (A50514)
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
