Fluid film
   / Fluid film #1
Soapandbacon
Cleveland, Ohio
Kubota BX25D
I've run across a few postings that mention something called fluid film. Can anyone elaborate on this product? Pros vs cons and what exactly is it for? Thanks , sorry if this is a stupid question ... Newbie here.
   / Fluid film #4
+1 on Fluid Film. Inhibits rust and it doesn't evaporate like WD40. Keeps metal looking shiny and new.
   / Fluid film #5
50/50 mix of acetone and ATF is also a good solution to rusty bolts and rust prevention. Much better than WD40 and similar products. Also.....much cheaper. Use it all the time in the shop.......I call it the miracle solution.:thumbsup:
   / Fluid film #6
And if you add a thinner (kerosene/mineral spirits/etc.) and a little lanolin (like is in Fluid Film) you get a concoction called Ed's Red. Great for cleaning guns and removing shotgun plastic wad fouling. It is a great for penetration.
https://www.google.com/search?q=eds+red+solvent&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:eek:fficial&client=firefox-a
Another option for penetration solution is Kroil but it is expensive.
   / Fluid film #7
I like to use fluid film on the shiny hydraulic cyl rods to protect them when long idle, and also I sometimes spray it on tools that may have gotten a bit damp.
   / Fluid film #8
Great tip on Ed's Red. Never used it but will give it a try later this year.....thanks!!
   / Fluid film #9
I can honestly say, Fluid Film is good stuff. I don't ever plan on being without it.
James K0UA
   / Fluid film #10
Fluid Film is not a penetrant. It is a more of a rust inhibator and coating, or a lubricant. If you need a penetrant, any of the home remedies suggested are great, but they will not be as effective or hold up as long as Fluid Film will in its intended purpose.
Brian
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
KOBELCO SK170-9...
2004 GMC Sierra 3500 Utility Flatbed Truck (A60460)
2004 GMC Sierra...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
