Where to add engine oil in Ford 2000?
   / Where to add engine oil in Ford 2000? #1
FordTwoThousand
Can anyone tell me where do you add engine oil in a ford 2000 tractor? I think it is a 1962 year?
I included some pics in hopes someone can maybe circle the area that I should be focusing on.
Thanks so much!
   / Where to add engine oil in Ford 2000? #2
Fill tube is just ahead of the distributor, remove the cap with the wing nut.
Thank you so much!
Would you happen to know what oil should be used in such a tractor?
   / Where to add engine oil in Ford 2000? #4
i'd personally put in 15w4 C/S rated oil.
for the trans sump, diffy sump, and hyds sump ( all seperate ), you can use a utf oil meeting M2c134 spec. OR use 80w90 gear oil in the trans and diffy, and UTF in the hyds.
spin on filter will be a fram ph8a, supertech st8a, napa 1452 or 1515, motorcraft fl1a , dual 300 etc.
ignition parts for that machine will be:
Side-Mount Distributor: 8n thru 4 cyl thousand series
gap points to .025
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
side mount points hold down screws #8-32 X 3/16
FORD AUTOMOBILE dealer parts counter. come with built-in lockwasher. p/n 355047-S7 (#8-32 X 0.19)
All 4 cyl models can use AL-437 or champion H12 spark plugs instead of OEM Champion H10 or AL 216 plugs.
ps.. time to get a owners manual, and a fo20 service manual
   / Where to add engine oil in Ford 2000? #5
Hey, I'm curious what year is your Ford 2000? Have you ever replaced the voltage regulator?
   / Where to add engine oil in Ford 2000? #6
my ford 2000? it's a 63-64 model with some parts from other 55+ models mixed in :)
i have an alt on it. so no external vreg.
   / Where to add engine oil in Ford 2000? #7
I changed the system to 12 V and use an alternator instead of a generator and don't use a voltage regulator.
2022 BMW SUV (A53424)
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
