Cub Cadet M48-KW Tank Problems
/ Cub Cadet M48-KW Tank Problems #1
rtyndallnc
Member
Angier, NC
Bob-Cat Pro7000, Bob-Cat Pro6000,Troy-bilt Mustang RZT 50, Massey 1225, Long 460, Kubota ZD25
I have 2006 Cub Cadet M48-KW Tank that has a couple of problems I need help with. Bought this used and only had it a little while.
First, I was having an issue with it being hard to start. I had to play around with the choke while holding the key and it would start in about 20 to 30 seconds. I changed all the fuel lines as they were old and crumbling. Replaced the fuel filter and checked/cleaned spark plugs and Put a new fuel pump on it. It now starts easier but while actually mowing if you hit a bump it acts like it's going to turn off but never actually does. Also when I engage the PTO it sounds like it's going to cut off yet never does.
Second problem is the PTO. It engages fine when I first start cutting but after using it for 20 to 30 minutes, if I turn off the PTO it does not want to start back. First time this happened I started driving the mower and the PTO kicked in. Same thing happened again so I tried that and it did not work. I was basically finished mowing so I just parked it. I have noticed this mower will cut in reverse, not sure if that is because it is a commercial mower or if something is wrong there. I know my Troy Bilt residential RZT will not cut in reverse.
Any and all help appreciated
/ Cub Cadet M48-KW Tank Problems #2
I don't have an answer but I do have some info... I have a 2006 MK48-KW which I bought used (about 400 hours). I have both of these problems. Mine won't start without full choke and after running for a while the PTO will sometimes not reengage after stopping. Since it will always start and I can always eventually get the PTO engaged I have just lived these quirks. I mow just under 2 acres every week with no problems.
I have wondered if one day the PTO will fail to engage altogether. One detail: I run two high lift blades in a cross on each of the three spindles - which definitely adds load to the PTO. I find I get the best cut that way and when I use a bragger it really works well.
-Mike
My M48 Tank that I bought used did not come with a ROPS. Does anyone know where I can find one? I have googled it and can't find anywhere to actually order one.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
44" HYD MINI WOOD GRABBER BUCKET (A60430)
44" HYD MINI WOOD...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
