New max 28 and new member
   / New max 28 and new member #31
I just bought a off the show room floor Mahindra Max 28 XL Shuttle. Loader and Backhoe. It seems to do everything I need here at home ( mini farm ) but my Differential foot pedal is stuck in the down position and the DIF is IN all the time not good for scooting back and forth on the road to and from the barn. My dealer has never seen this and is clueless on it. If I don't hear back from Mahindra I will be mad. Being a retired military Tank/Tracks mechanic I will fix it myself not a problem BUT hey I only have 6 hours on this machine. So far the operation of the 28 max is great. Any info will help thanks.
the pedal for the diff lock on mine stays fairly 'down' as well, but will actually drop a little bit lower if stepped on. I can't tell if mine works or not though, I may have the tractor taken in for that issue towards the end of july.
   / New max 28 and new member #32
Spray a little WD-40 and let it run down the shaft and then work it up and down usually will get them unstuck I've seen this on many tractor brands if not used much they will cease up a bit but WD-40 usally will free it up.
   / New max 28 and new member #33
WD-40 on the shaft and work it up and down should free it up.
2018 Gatormade 20+5 Gooseneck Trailer (A52128)
2018 Gatormade...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
