John Deere 300 Industrial hydraulic problems
   / John Deere 300 Industrial hydraulic problems #31
If it is there it'll usually be on a metal tag bolted to the pump.
   / John Deere 300 Industrial hydraulic problems #32
Okay. I'll look for it.
   / John Deere 300 Industrial hydraulic problems #33
The back and forth steering trick worked. Started 3 times in a row!
I didn't find a metal tag on the pump but there are #s on the front.
   / John Deere 300 Industrial hydraulic problems #34
I still havent found the screen. I took photos underneath. Can someone photoshop an arrow where it is? I can't seem to find it.
While Im at it, anyone know a reasonable replacement controller for the loader? Someone tried to patch a leak somewhere on top by laying on about 1/2" of weld. Started leaking a couple days ago. Not sure I should try to repair it.image.jpg
   / John Deere 300 Industrial hydraulic problems #35
Is it a cessna valve set?
   / John Deere 300 Industrial hydraulic problems #36
I wish I knew more about these things. All I can do is take photos and let you tell me until I learn about it. I appreciate the patience you guys are showing a newbee. I used to rebuild 94-96 Impala SS's and was on a forum for years. The amount of knowledge that gets passed down is amazing. Just wanted to say Thanks!
I'll drop a photo in a minute.
   / John Deere 300 Industrial hydraulic problems #39
   / John Deere 300 Industrial hydraulic problems #40
If you may want to add a grapple later youbmight want to get a 3spool valve instead. If it's a cessna when you remove the valve it will say cessna somewhere on it. Best not to replace with the same brand since you can't rebuild them.
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
9202 (A50322)
9202 (A50322)
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
