John Deere 300 Industrial hydraulic problems
   / John Deere 300 Industrial hydraulic problems #31
If it is there it'll usually be on a metal tag bolted to the pump.
   / John Deere 300 Industrial hydraulic problems #32
Okay. I'll look for it.
   / John Deere 300 Industrial hydraulic problems #33
The back and forth steering trick worked. Started 3 times in a row!
I didn't find a metal tag on the pump but there are #s on the front.
   / John Deere 300 Industrial hydraulic problems #34
I still havent found the screen. I took photos underneath. Can someone photoshop an arrow where it is? I can't seem to find it.
While Im at it, anyone know a reasonable replacement controller for the loader? Someone tried to patch a leak somewhere on top by laying on about 1/2" of weld. Started leaking a couple days ago. Not sure I should try to repair it.image.jpg
   / John Deere 300 Industrial hydraulic problems #35
Is it a cessna valve set?
   / John Deere 300 Industrial hydraulic problems #36
I wish I knew more about these things. All I can do is take photos and let you tell me until I learn about it. I appreciate the patience you guys are showing a newbee. I used to rebuild 94-96 Impala SS's and was on a forum for years. The amount of knowledge that gets passed down is amazing. Just wanted to say Thanks!
I'll drop a photo in a minute.
   / John Deere 300 Industrial hydraulic problems #39
   / John Deere 300 Industrial hydraulic problems #40
If you may want to add a grapple later youbmight want to get a 3spool valve instead. If it's a cessna when you remove the valve it will say cessna somewhere on it. Best not to replace with the same brand since you can't rebuild them.
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53472)
NEW 2024 LOAD...
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
2008 JLG SKYPOWER 800AJ MANLIFT (A51246)
2008 JLG SKYPOWER...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
