John deere 820
   / John deere 820 #51
Have tried using any diesel fuel conditioners/inj cleaner fluids?
   / John deere 820
Yes I have. When I crack open injectors there is a noticeable change on each one. Not sure what else to check?? Everything works like its supposed to. It don't run hot. Like I said it just at certain Rpms. I'm stumped!! Fuel pump is new. Filter is new.
   / John deere 820 #53
About the only thing left to do is pull the questionable injector and have it tested or replace it.
   / John deere 820
That's what I was thinking. I do have one injector so guess i will try each one to see if that cures the problem. I'm hoping its not a compression issue or valve issue. It has way to much power for that to be it.
   / John deere 820
Well found problem with miss I'm having. It's the injecter pump. It has a stanadyne pump on it. I found a diesel repair house that will rebuild and reseal for 450. Going bring next week and hope I'm done working in this thing
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55314)
Koyker Loader...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
More info coming soon! (A55851)
More info coming...
