3500 Dodge diesel under water. Any Hope for revival?
   / 3500 Dodge diesel under water. Any Hope for revival?
Ken:
Sure sounds like someone is making a statement with the truck right now.! Just watch out for the Hail, Lightning and the tree to fall on it or a sink hole to swallow it up! hahaha...
Older F350 with that Cummins in might just be a nice ride.
Mark
Mark, It is kinda out of my hands now, They brought a boom wrecker in yesterday and got it out about 6:30 last night. It is in Louisville, Ky now waiting for evaluater to come look at it. Ken Sweet
   / 3500 Dodge diesel under water. Any Hope for revival? #72
Look at it this way... If you buy a new one that is supposed to take you to the end of it then you might get a few more years out of it?
I've had a couple dodges and personally like the new Ford Powerstrokes. Although can't beat the simplicity of a Dodge Cummins. Currently in a Toyota but not pulling over 10,000lbs with it.
   / 3500 Dodge diesel under water. Any Hope for revival? #73
look at it this way Ken maybe the man thinks you have a few more years then you thought and you need to get 1 more newer truck that will take you that far
   / 3500 Dodge diesel under water. Any Hope for revival? #74
Try and find an 05 Ram, last pf the pre-emissions 5.9's.
   / 3500 Dodge diesel under water. Any Hope for revival? #75
Actually any pre 2007.5 is pre emission. The 6.7's were where they started with all the DPF and EGR valves. Technically any pre 2004.5 truck has less emissions. Starting in Jan 2005 they started putting cats on the Cummins and they had "in cylinder EGR" which was just cam shaft timing that left a little exhaust in the cylinder after the exhaust stroke. These trucks also added a 3 injection event where the pre 2004.5 trucks had only 2. From a practical point of view, there isn't a lot of difference between them and the emission equipment on the 2005 trucks and later didn't really cause any problems. I also think some of the late 90's trucks may have had cats on them also.
   / 3500 Dodge diesel under water. Any Hope for revival? #76
So a 2007 would also be a good buy then? How were the auto trans in those?
Aisin? They are a Toyota supplied unit?
   / 3500 Dodge diesel under water. Any Hope for revival? #77
They had the 48RE for transmissions and if the truck isn't hot rodded, they hold up well. An early 2007 truck (before Jan 2008) is considered by some as the holy grail of the 3rd gen Cummins.
   / 3500 Dodge diesel under water. Any Hope for revival? #78
Thanks. So, if the tryck id programmed, expect the trans to ge a weak link? Cummins ahould be ok though?
That is the only thing that scares me about a used diesel, hot rodders!!
   / 3500 Dodge diesel under water. Any Hope for revival? #79
Just my experience from talking to people and reading the Cummins forums, about 90% of the transmissions problems come from people that chip the truck and start turning up the power levels. I think this holds true for all the makes, not just Dodge. It seems like a high percentage of the trucks have had some kind of chip on them. My truck came with a chip on it but so far everything is holding up. A transmission has a lot of wear parts in it so you can just expect a rebuild at some point, its just a matter of if its at 80,000 miles or 200,000 miles.
I'd like to say the 5.9 common rail Cummins is bulletproof, but that wouldn't be true. The weak link and one that can cause a engine meltdown is the injectors. Injectors are a wear item and need replaced at some point, usually somewhere between 100,000 and 200,000 miles. People get into problems when they ignore a bad injector and start burning holes in pistons, thinning there oil etc. Hot rodding the truck can also be hard on injectors.
   / 3500 Dodge diesel under water. Any Hope for revival? #80
I've found that the trans was always the weak link in the rams. Usually go out right at 100,000 miles.
The key is accepting that will be an expense and when doing it have it built right. There is an 01 I work on that has 310,000 on it now. Trans went right at 100,000. Built it with top of the line materials, including a billet torque converter that was $1400.
BTW. This truck is pushing 600 hp and the last 30,000 miles have been put on by his 19 year old son.
2012 ford f550 service truck (A52377)
2012 ford f550...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2016 Ford F-450 4x4 Ambulance, VIN # 1FDUF4HT3GEC45874 (A54865)
2016 Ford F-450...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2020 Ford F-150 Crew Cab Pickup Truck (A55788)
2020 Ford F-150...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A55788)
2006 Chevrolet...
