Hydraulic Cylinder Drawing/CAD Model?
/ Hydraulic Cylinder Drawing/CAD Model? #1
avc8130
Northern, NJ
Kubota L45
Does anyone know where I could find technical drawings or even a CAD model of a hydraulic cylinder that would be suitable for use on a grapple? I'm working on designing a grapple in Pro/Engineer and I really want to be able to put the cylinder in my model to check for range of motion and to make sure I don't get any interference.
ac
/ Hydraulic Cylinder Drawing/CAD Model? #3
If you have a supplier in mind it would be best to ask them. that way you know what you will be getting and that it will fit correctly. If you are going thru all the CAD design parts then for it to actually work correctly you need the model from the company supplying/building the cyl.
I dont know if Surplus Center has cad models but they supply part numbers of cylinders they have available and manufacture so then go after the manufacture for a model off a download or sales & support from their site.
Mark
/ Hydraulic Cylinder Drawing/CAD Model? #4
I have used the drawings from Surplus Center many times to create my own models. They should have all the information that you need.
Oh wow, I've never seen that site before.
I realized now I need to pick a cylinder first as they don't seem to be 100% universal.
Any suggestions for a cylinder to base my grapple design around?
I don't know what diameter or stroke is commonly used.
ac
/ Hydraulic Cylinder Drawing/CAD Model? #6
ac
The cylinders on my grapple are 2 1/2" with 8" stroke.
/ Hydraulic Cylinder Drawing/CAD Model? #7
Use a cylinder meeting ASAE dimensional standards. Most grapples do, and you are assured of always finding cheap, commonly available replacements.
You know, I had wondered if there was some sort of standard for exactly this reason.
Any links to an example?
ac
/ Hydraulic Cylinder Drawing/CAD Model? #9
/ Hydraulic Cylinder Drawing/CAD Model? #10
you could go directly on Parker web site than make your with the spec you need than download it!
/ Hydraulic Cylinder Drawing/CAD Model? #11
While working in TurboCad the past month I had similar issues and found that 8" stroke cylinders were available from 16" closed pin to pin to over 20" closed pin to pin. For my needs the Prince tee cylinders with the 16" pin to pin model was the best choice for the geometry at hand. My point being you need to sort out the type cylinder that is needed to work in your application and then adjust the design. Playing with the cad program and browsing the different cylinders I was able to work out just what was needed before spending a nickel.
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Godwin Pump (A59228)
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
