Not an expert by any means but will the trans and axles take the additional power or will you end up chasing failures through the drive train?
You will have to turn up the fuel pump unless the turbo is just set to break even. If you don't it will damage your engine.
Please explain. I'm lost on this one.
It will run lean once you add a turbo, and will need more fuel, or it will blow up. Anytime you add more incoming air, you need more fuel.
What???? Please explain how this will cause the engine to "blow up"?
Unless you run it so lean that you put the fire out there are no problems from running a diesel lean. Even then it's just going to miss and sputter.
A lean gas motor will burn the pistons, a diesel no.
I tell you what, add a turbo to yours. You will find out first hand what happens.
Again, just my :2cents:. If the OP has power problems, sell the tractor and get one that will do what needs to be done.
