Tie/stap down procedures?
   / Tie/stap down procedures? #1
Hotelsierra
California
Ford 3000
I am curious what you guys are using to secure your tractors to trailers? Chains I would think, but I am new to trailering tractors, so I dont have a clue.
What type of chains and binders? Where are the secure points?
Any info securing a load is appreciated.
Thanks!
   / Tie/stap down procedures? #2
Thanks!
The one thing I will offer is check with your State (or neighbouring ones, if you will haul that far) concerning certifications on the chains/straps/binders.
The regulations changed here (Ontario, Canada) not long back, if you don't have the right tags on the chains.... then MTO considers them invalid. Partly this was done to fight the flood of knock-off junk coming in from Asia.
Post here if you have a loader (FEL), type of trailer, and what rear attachments you will/want to haul and I'm sure the seasoned tractor-haulers will have plenty of suggestions.
Rgds, D.
   / Tie/stap down procedures? #3
I use 4 10' long 5/16 G70 chains. One on each corner of the tractor with boomers. For the FEL and 3 point implement I use a 2" strap.
Chris
   / Tie/stap down procedures? #4
General rule seems to be chains for the vehicles and straps for the attachments.
   / Tie/stap down procedures? #5
Great topic! I just purchased my first trailer to move my Kubota BX25 & attachments and could use help on what straps/chains I should use and how to attach them! Any suggestions would be appreciated!
   / Tie/stap down procedures? #6
Here is how I have been securing mine, g70 5/16 chain, and ratchet binders. I bought 2 20' chains at Lowes, had them cut in half. I also have 2 other 20 footers from Lowes, in case I need longer ones. two on the front over the bucket, since the tractor is so small, and one on the backhoe. Not shown in the pictures is a 2" strap over the backhoe bucket
   / Tie/stap down procedures? #8
View attachment 328685View attachment 328686View attachment 328687
It doesn't look like this tiedown configuration meets CFR393.130 Rules for securing heavy vehicles, equipment and machinery:
"(c) Securement of heavy vehicles, equipment
or machinery with crawler tracks or
wheels. (1) In addition to the requirements
of paragraph (b) of this section,
heavy equipment or machinery with
crawler tracks or wheels must be restrained
against movement in the lateral,
forward, rearward, and vertical direction
using a minimum of four
tiedowns.
From here: Maintenance
   / Tie/stap down procedures? #9
I do a 4 point ( 4 chains & binders) and tie my chains to the frame of the tractor. I don't worry too much about the equipment attached as I don't go very far or fast.....note in his pics how kernal hooks the chain hooks on the trailer.
   / Tie/stap down procedures? #10
Whatever you do, dont run a strap (yes, straps work is heavy enough) through any part of the machine as it will get cut. If you use straps, they should only go from trailer to chain. The exception would be axle straps and straps over the top to control 'bounce'.
   / Tie/stap down procedures? #11
he's got 4 chains on it. I'm curious what you would suggest he do differently... I ask because I did basically the same thing with mine the other day (for a test-tow, but if the process of strapping it down needs modification I'd rather get in the habbit sooner than later).. two over the front bucket to the front of the frame/brush guard, and on mine I had two where the lower links on the 3ph would normally attach running to the back of the trailer (not straight back, but not to the back corner). then everything was pulled down tight. I didn't do anything with the backhoe on mine cause I've got pins in the arm to keep it from moving up/down and side to side (altho I do recall the mahindra docs saying I need to drop the arm/bucket to the bed and then run a strap over that, for the distance traveled it didn't seem important at the time)
what should one do differently? front chains under the bucket? more/less angle on the chains?
tiedowns.
   / Tie/stap down procedures? #12
It looks like one chain on the rear.. could be the picture.
   / Tie/stap down procedures? #13
there's 2 on the back. the other one seems to follow the edge of the trailer, I had to look closely myself.
   / Tie/stap down procedures? #15
I meant to mention, before I got interrupted by a phone call, that there appears to be only one chain and one boomer on the back and that that the one chain goes around to the other side of the trailer. I don't see another boomer (and hence another chain) in the pine cone pic.
   / Tie/stap down procedures? #16
gotcha. so aside from that, it's good? (assuming that what looks like 2 chains is indeed 2 chains on the back ;) )
   / Tie/stap down procedures? #17
Two in the front, two in the back, tied to prevent movement in all three axis, 5/16" G70: should be GTG.
:thumbsup:
   / Tie/stap down procedures? #18
The chains look like they meet the requirements although some states require the back hoe and FEL to be separately strapped/chained to prevent movement. I use 2" ratchet straps for this, other than that it looks to meet the federal requirements provided the strength of his chains is adequate. IIRCC, each chain has to have an operating load of minimum of 50% of the maximum weight of what you are chaining down, so 4 chains would be capable of sustaining 200% of the maximum weight of what you are hauling
   / Tie/stap down procedures? #19
In my state the FEL would each need a independent tie down as mentioned in addition to the 4 chains on the tractor.
Chris
   / Tie/stap down procedures? #20
How's about some critique of what I did recently. I don't haul far, fast or often. I used two, two inch ratchet straps. On the front, I wrap the strap around the front axle in two loops. And likewise, on the back, I make a single loop around the rear axle, being careful not to engage any sharp surface. This is for my B2620 on a tandem axle equipment hauler. Oh Oh, it sounds like I need to get some chain and binders already.:eek:
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) 48"X7 1/2' ADS DRAINAGE PIPE (A60432)
(1) 48"X7 1/2' ADS...
(4) ROADGUIDER QH100 235/80R16 TIRES (A60430)
(4) ROADGUIDER...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
