Buying Advice BX2660 (2010, 267 hrs) or BX2360 (New with Warranty)
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #11
Hydraulics run on the same fluid as the HST tranny. Be sure HST works normally and the FEL likewise. The 3 point lift in back also raises/lowers the mower deck... you generally use one or the other at a time, not both.
Thanks GD4. Not knowing what you don't know is intimidating. I am enjoying learning though.
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #13
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #14
Check the color of the oil filter. The filter installed at the factory is black and would be replaced by a white filter at any subsequent service. I bought my BX2660 used with 135 hours and found out after the sale about the filter color scheme. Taking the deck on and off dosen't take long but it does require a couple of trips around the machine, kneeling and some time flat on your back,
Thanks everyone for the information. Newbury, most likely it does have that HST fan. But I understand an aftermarket skid plate will protect it (if it's not already toast). Thanks.
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #18
Do these BX's have the infamous easy break HST fan?
Yes they do though the newer models have a more effective protector than earlier models, it is still pretty vulnerable and most put a protector from Bxpanded or Bro Tek, we have them on both of ours, John Deere SCUTS prior to the 1023/26/25 had this design also.
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #19
If you keep the MMM on the unit, the fan will be protected!
   / BX2660 (2010, 267 hrs) or BX2360 (New with Warranty) #20
With my luck I'll probably have to eat these words next week but we've run our BX for 8 years without damaging the fan, mostly by staying on familiar terrain. However, it's obvious that going into any place with dead sticks on the ground and "breaking trail" through tall overgrowth would run a great risk of something taking out that fan. The skid plate is one of those "better safe than sorry" ideas, though.
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2025 CFG Industrial MX50R (A50123)
2025 CFG...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
