Rotary Cutter Pto Hp per foot of shredder
   / Pto Hp per foot of shredder #11
Thats a beefy tractor. Should handle about any HD 6 or 7' cutter with ease. And I would even consider a twin spindle 8' cutter on it. Might have to slow down a bit in the extra thick stuff, but would be quicker in the not-so-thick stuff.
   / Pto Hp per foot of shredder #12
Leonz, different places have different names for the same thing. "Slasher" a common name for any kind of rough cut mower in Australia, they use "Shredder" in TX to mean the same thing.
There are 92 ads in the Farm and Garden section of the Houston Craigslist advertising "Shredders" and of those, only 2 also contain the word flail (houston farm & garden - all classifieds "shredder" - craigslist).
Aaron Z
The Hiniker and Mathews folks use flail shredder so.....
guy thanks for the help
   / Pto Hp per foot of shredder #15
You also have to watch the geometry of the 3pt on the brush hog (pa name) and the 3pt on a compact tractor. I just bought a 6' brush hog for my compact and although it works the geometry is just wrong. Most of these larger units are made for a utility type tractor that sits higher off of the ground, with the factory set up my 3pt hitch arms and the center link all run up hill an I really can't lift the mower up very high because in the down position the arms are already half of the way up. The tractor handles the mower just fine and definitely has the PTO HP needed for it but it just doesn't fit right. I don't know if anyone makes a larger unit specifically for a compact tractor but you may want see.
The fix isn't that hard all I have to do is put two bolts in where the 3pt pins are now to hold the braces and drill new holes down lower to reinstall them, then remove the floating top link from the mower and that will drop the center link down also, but that said the distance that the pins are lowered will also have to take into account where the PTO shaft runs when lifted so it clears the mower deck. I guess I could also install taller tires on the tractor, but that isn't going to happen. :laughing:
   / Pto Hp per foot of shredder #16
Not my usage-Hinikers and many others that make flail shredders.
   / Pto Hp per foot of shredder #17
as said atlest 5hp pre foot of shredder.we are pulling a 14ft ridged shredder with 70hp tractors that are 65hp on the pto.
   / Pto Hp per foot of shredder #18
Shredder is just a generic term and can be applied to many pieces of equipment.
Kinda like the term "saw"
It can be applied to:
Chainsaw
Circular saw
Reciprocating saw
Miter saw
Table saw
Hack Saw
Cross cut saw
etc.
A "shredder" doesnt always have to be a Flail mower
   / Pto Hp per foot of shredder #19
Chainsaw
Circular saw
Reciprocating saw
Miter saw
Table saw
Hack Saw
Cross cut saw
etc.
It can also be a chipper...
Aaron Z
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
