Ford says no to Diesel F-150
   / Ford says no to Diesel F-150 #221
Honestly the truck wasn't worth saving, good drivetrain and that's it. Minor engine problems that were easily fixable but I was so tired of it I wouldn't spend another dime on it..
That is one of the problems with keeping these old girls. You simply get tired of driving them. Too bad, because with the modern cab features, the old engines and drive trains are something I could live with.
   / Ford says no to Diesel F-150 #222
Honestly the truck wasn't worth saving, good drivetrain and that's it. Minor engine problems that were easily fixable but I was so tired of it I wouldn't spend another dime on it. He has sunk a ton of money on it in the past two weeks and plans on having it on the road tomorrow.
Body was shot eh?
Id probably still hold onto the running gear. Thats the most sought after part. Engine/trans etc. would make a great swap into just about anything.
   / Ford says no to Diesel F-150 #223
Most of the old Dodges were used up. They were often worked hard and put away wet. The truth is the newer trucks are much better all around, but those early 12 valves were so simple in design and very inexpensive to fix. You could probably buy a set of injectors for the cost of one injector on a common rail.
   / Ford says no to Diesel F-150 #224
Would love to see the VW Amarok pickup in the US...
   / Ford says no to Diesel F-150 #225
Even if they did I'm not sure if they would put a diesel in it. Not all VW models are offered with a diesel.
   / Ford says no to Diesel F-150 #230
Hey there's an idea... a duty-free car dealer! :)
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
eXmark Quest Zero Turn Mower (A53117)
eXmark Quest Zero...
2022 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A51692)
2022 Mercedes-Benz...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2005 BIG TEX 18 TANDEM AXLE TRASH TRAILER (A53843)
2005 BIG TEX 18...
