Backing tractor and implement onto your trailer??? How many do this??
/ Backing tractor and implement onto your trailer??? How many do this?? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have been wanting a 32' gooseneck trailer to haul my tractors and (shredder / disk) ect. I was recently told that doing so would really load my truck, unless I backed the tractor and shredder / disk / ect. onto the trailer to keep most of the wt. of the tractor over the trailer tires. Is this a realistic expectation? I am pretty handy with farm equipment, but thinking about backing a 10' shredder onto a narrow flat deck trailer seems like it would be pretty difficult to me. I want your feedback on this? Anyone here have small rails (like railroad iron) or something attached to floor to guide tires of implement? any and all feedback / thoughts welcomed. thanks again.
/ Backing tractor and implement onto your trailer??? How many do this?? #2
You'll open a can of worms here talking about tongue wt., but either way you are going to have to back it on or off. I'd rather back off (unloading) and if things get a little sloppy the last few feet, you can generally get away with it. If you have a loader, a hitch of some sort on the bucket makes pushing your implement on easy, as your steering (reaction) is much faster than on the rear. This will put your lighter implements up towards the frong leaving room for your heavier tractor over or at least close to the trlr. axles to avoid excessive tongue wt.
/ Backing tractor and implement onto your trailer??? How many do this?? #3
It depends! What is the total weight of implements and trailer and then what is the towing capacity and tongue weight capacity of your truck. Where are the axels located front to back on the trailer and how much overhang from axel to hitch on your truck. Every combination creates its own set of criteria. It may be as simple as relocating the center of gravity by moving the trailer axels to match your loading plan. A 32' trailer designed to haul heavy loads is alone a good load on its own and may require three axels or maybe dual wheels. They put the tongue weight right on the truck axel. Most of what I have seen that long for towing by small trucks are fifth wheel type like travel trailers and are for fairly light loads. A top notch trailer dealer has all the formulas to plan your load and figure out your optimum unit locations. You need to know the weight of each item and its center of gravity. This is the scientific way hardly anyone bothers with and then wonder why they are having problems. Being light on the tongue is worse than being tongue heavy. My Dodge 350 with duals has greater tongue capacity than a 350 with single tires. Trying to crowd a lot of wheeled stuff on a trailer greatly complicates your tie down situation to be legally correct and can take a lot of chains and binders.
Are you in the range where your state considers you a commercial hauler? They get more weight and equipment balance scrutiny and require you to have a CDL to drive the combo. CDL operators do not get any slack on knowledge of the rules of the road. I can load my 1 ton Dodge and trailer to the point of requiring a CDL.
/ Backing tractor and implement onto your trailer??? How many do this?? #4
The owners manual to the Bobcat CT235 I had said to back it on with or without a implement on the 3PH.
/ Backing tractor and implement onto your trailer??? How many do this?? #5
I back mine on, but mainly because the trailer is too short (16') for the tractor with the loader and anything on the 3pt. The weight seems to balance well this way. It works just fine as I take the time to make sure I am lined up straight and the ramps are set right. Like anything, once you do it a few times it gets easier. I find it critical to be in 4wd when doing it or I can lose traction at the breakover point onto the deck.
Not sure why you would have an issue with a 32' trailer unless your tractor is waay bigger than any CUT I have seen...
/ Backing tractor and implement onto your trailer??? How many do this?? #6
4WD is very important, especially with a steel deck.
/ Backing tractor and implement onto your trailer??? How many do this?? #7
If you overload the truck you will know it. It will handle poorly. If you under load the truck you will know that also. The trailer will feel squirrelly. Maybe even whip. You would have to be the judge of the distribution of the weight. Or have someone that knows help you.
/ Backing tractor and implement onto your trailer??? How many do this?? #8
A good shortcut for checking that your bumper-pull trailer is loaded (roughly) properly is to measure the height to the top of the wheel well or the bumper with the trailer un-hooked, then hook up the trailer and load it. When you're done, the truck should squat an inch or two. At least then, you'll know you're not tail-heavy, which causes a lot of problems.
Really, you should also put some thought into making sure you're not exceeding your rated tongue weight, but that's a whole other can of worms.
/ Backing tractor and implement onto your trailer??? How many do this?? #9
Best way to figure it out is take the truck/trailer to a scale empty and get the weight of the axles. The load up the tractor/impliments amd reweigh it. Balance the load out to have 10-15% of the weight or max axle weight rating and make sure nothing is overloaded or in cdl range. It's cheap insurance for yourself.
/ Backing tractor and implement onto your trailer??? How many do this?? #10
Ive backed mine on, but you REALLY need to pay attention to were your front wheels are on the ramps.
/ Backing tractor and implement onto your trailer??? How many do this?? #11
On the very few occasions that I need to load my skid steer into the dump trailer, it has to be backed on due to the rear of the machine being heavier than the front. The machine will tip back onto it's rear if I try to drive on.
It's just a fact of life that the machine is heavier in the back to counter any weight picked up by the lift arms whether it's a bucket full of material or a load on the forks.
/ Backing tractor and implement onto your trailer??? How many do this?? #12
I back mine on when hauling.
Chris
/ Backing tractor and implement onto your trailer??? How many do this?? #13
I back mine on just incase a rock gets thrown into the cab while on the road. I figure the rear window is cheaper and easier to replace than the front windshield.
/ Backing tractor and implement onto your trailer??? How many do this?? #14
Good point, bigtiller
/ Backing tractor and implement onto your trailer??? How many do this?? #15
I always back on excavators. Tractors, it just depends. 2WD in wet weather, I just get it on whatever way I can. Once on the trailer, I just watch the truck and get a partial squat and call it good. Then binder her down there.
/ Backing tractor and implement onto your trailer??? How many do this?? #16
I have to load my 9 foot offset disc by backing it on my 24+5 foot gooseneck. Then disconnect the hitch and back over the tongue. It took a few times backing and pulling forward with the tractor because the rear offset disc gang would dig in on the ramp and move the whole disc to trailer left.
After some practice, I can back the disc up on the trailer and get it where I want it. As you can see in the photo below, even after disconnecting the tongue, my tractor's front tires are right at the dovetail and the loader bucket sits on the ramps.
A 32 foot gooseneck might give you enough room to drive it on and back it off and still be within CG and weight limits over each axle. It depends on what the overall lengths of the implement and tractor are, or if you will leave them connected or disconnect the hitch.
One thing to remember backing the tractor and implement on is to keep an eye on the front tires as you go back up the ramps and also how close to the edges of the dovetail you get the front tires. They will get close as you practice getting it straight on.
I hope this helps.
/ Backing tractor and implement onto your trailer??? How many do this?? #17
I have hauled a few skidsteers. Always interesting... They are heavy for their size compared to a CUT, and so short of wheelbase. Even on a low trailer, the first couple of times it feels like you are tilting a lot, and ready to roll over backwards or forwards(depending on how you're loading). After that it is no big deal.
/ Backing tractor and implement onto your trailer??? How many do this?? #19
My trailer is usually to short so I back the shredder on and un-hook then drive tractor on forward so tongue is under tractor and bucket is over top of shredder. May check your wheel spacing the 10ft shredder,my 8ft doesnt allow for much wiggle room and my 12ft flat-deck shredder,not going to happen. When I had my smaller 50hp I would just drive straight on and rest the loader on the neck of trailer. My dually handled it fine,and you can look at the truck and tell if bed is in the air or its squatting bad to adjust your weight.
/ Backing tractor and implement onto your trailer??? How many do this?? #20
Not something you can do in reverse order. Clever.
(INOP)2015 FORD F-250XL SUPER DUTY TRUCK (A60430)
(INOP)2015 FORD...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
John Deere 6300 (A60462)
John Deere 6300...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
