bigballer
- Joined
- Jun 2, 2006
- Messages
- 666
- Tractor
- 2006 Kubota L3400
Also can turn the drive pulley by hand so its not seized.
coil will not affect it turning over, only affect the firing of the sparkplugs
I pulled the ignition switch and found the ground wire. 12.4.. there is a rocker switch to raise and lower the wheel and the works I see voltage drop to 12.1 and it raises / lowers the wheel.
Not sure what you're saying: '...lower the wheel and the works...'
You seem to get a slight V drop when you energize the wheel raise/lower switch? Yes?
Take positive lead of meter and put on pos post of battery. Take negative lead from meter and run it to housing of starter and see if you get a reading of Voltage. If NOT, you may not have a good ground for the starter.
Post results.
