hauling a 8,000lb tractor
   / hauling a 8,000lb tractor #1
flyingcow
aroostook county maine
i am in the position of needing to update pickups. i have a 2006 Dmax,3500 crew, 8ft bed, SRW. I really only need the pickup to haul my 26ft GN 3 or 4 times a yr(8,000lb tractor), inside of 20 miles. i really want a 1/2 ton ride most of the time. I am leaning towards an big liter 1/2 ton and putting air bags boosters on the suspension. Biggest and best for tranny coolers.
Any thoughts? And i have very little concern for the LEO's in this set up.
FWIW, i drive a 100,000lb truck for a living.
Also, only put on 10,000 miles a yr in my pickup.
   / hauling a 8,000lb tractor #2
If I understood correctly you want to haul a 8000lb tractor on a gooseneck. IDK how much your gooseneck weighs but that load will probably exceed the tow ratings for a 1/2 ton.
   / hauling a 8,000lb tractor #3
I AGREE, What does the GN weigh ?
   / hauling a 8,000lb tractor #4
Sounds like a job for a F150 Eco Boost. Drive one with 3.73 gears, not 3.55, 3.31, or 3.15's. You will be done with a big motor.
Chris
   / hauling a 8,000lb tractor #5
I want your duramax!
   / hauling a 8,000lb tractor #6
Chris
Pulling that much weight will kill that gas burner 6 cyl. Probably looking at what 12-13K ?
   / hauling a 8,000lb tractor #7
figure it's gotta be in the neighborhood of 4k depending on ramp design and body style.. might be a lil lower.. or a lil more.. but that should be ballpark.
4k trailer and 8k tractor... That has to be pinching even an exagerated 1/2 ton tow rating. not counting the gn adapter plate / hitch being added to the truck, and the weight of the helper suspension being added..
Wow.. and to think i got rid of a half ton and moved into a 1 ton to tow safer. this guy is aiming for near opposite direction on the hardware... :) Can't wait to see where this thread goes.
   / hauling a 8,000lb tractor #8
Well, I was thinking somewhere around 4-6 K for the GN. It's got to be heavy built to haul an 8 K tractor
   / hauling a 8,000lb tractor #9
at one local trailer place.. they have 14k rated gn's in a range of 3400# to 4300# the light ones have smaller, fixed, flipover ramps and only 1 jack, and the beavertail is wood, no rub rail.. just some stake pockets... the 4300# has rub rail.. 1 or 2 jacks, and flip over hd ramps that also slide or detach, beaver is self cleaning metal.
both are 14k rated.. teh one with ld ramps.. I'd figure it's more for carrying 1-3 smaller items. not 1 heavy one.. kinda like landscape trailer vs a car hauler. got thos here. both are rated 7k ( axles.... ) one has expanded metal floor very light, and ramp gate... . a ford 8n may fall thru the e-m deck. other has wood deck.. heavy ramps. weighs more.
go figure. :)
   / hauling a 8,000lb tractor #10
There is a similar thread going around right now from a guy with a Dodge Dakota trying to figure it all out. I'll make this short; go to a reliable trailer dealer and have them run the numbers. They have a computer program that will take the guessing out of it.. As a CDL commercial operator you must see plenty of the tail wagging the dog PU and trailer combos. I was behind one a while back, a 1/2 or 3/4 with a GN and a track hoe behind, slight down grade, car cut him off, he slammed on the brakes. He was all over 3 lanes trying to get it straight. How he missed everybody is a miracle much less that he somehow kept it out of the ditch. When I passed he was parking it. Probably had to clean his shorts some. A reliable trailer dealer is one like mine; if the tow rig you have is inadequate they will not deliver the trailer on their premises.
Ron
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2016 CATERPILLAR CB34B SMOOTH DBL DRUM ROLLER (A52707)
2016 CATERPILLAR...
2002 International 9200i Truck (A55315)
2002 International...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
