hauling a 8,000lb tractor
   / hauling a 8,000lb tractor #1
flyingcow
aroostook county maine
i am in the position of needing to update pickups. i have a 2006 Dmax,3500 crew, 8ft bed, SRW. I really only need the pickup to haul my 26ft GN 3 or 4 times a yr(8,000lb tractor), inside of 20 miles. i really want a 1/2 ton ride most of the time. I am leaning towards an big liter 1/2 ton and putting air bags boosters on the suspension. Biggest and best for tranny coolers.
Any thoughts? And i have very little concern for the LEO's in this set up.
FWIW, i drive a 100,000lb truck for a living.
Also, only put on 10,000 miles a yr in my pickup.
   / hauling a 8,000lb tractor #2
If I understood correctly you want to haul a 8000lb tractor on a gooseneck. IDK how much your gooseneck weighs but that load will probably exceed the tow ratings for a 1/2 ton.
   / hauling a 8,000lb tractor #3
I AGREE, What does the GN weigh ?
   / hauling a 8,000lb tractor #4
Sounds like a job for a F150 Eco Boost. Drive one with 3.73 gears, not 3.55, 3.31, or 3.15's. You will be done with a big motor.
Chris
   / hauling a 8,000lb tractor #5
I want your duramax!
   / hauling a 8,000lb tractor #6
Chris
Pulling that much weight will kill that gas burner 6 cyl. Probably looking at what 12-13K ?
   / hauling a 8,000lb tractor #7
figure it's gotta be in the neighborhood of 4k depending on ramp design and body style.. might be a lil lower.. or a lil more.. but that should be ballpark.
4k trailer and 8k tractor... That has to be pinching even an exagerated 1/2 ton tow rating. not counting the gn adapter plate / hitch being added to the truck, and the weight of the helper suspension being added..
Wow.. and to think i got rid of a half ton and moved into a 1 ton to tow safer. this guy is aiming for near opposite direction on the hardware... :) Can't wait to see where this thread goes.
   / hauling a 8,000lb tractor #8
Well, I was thinking somewhere around 4-6 K for the GN. It's got to be heavy built to haul an 8 K tractor
   / hauling a 8,000lb tractor #9
at one local trailer place.. they have 14k rated gn's in a range of 3400# to 4300# the light ones have smaller, fixed, flipover ramps and only 1 jack, and the beavertail is wood, no rub rail.. just some stake pockets... the 4300# has rub rail.. 1 or 2 jacks, and flip over hd ramps that also slide or detach, beaver is self cleaning metal.
both are 14k rated.. teh one with ld ramps.. I'd figure it's more for carrying 1-3 smaller items. not 1 heavy one.. kinda like landscape trailer vs a car hauler. got thos here. both are rated 7k ( axles.... ) one has expanded metal floor very light, and ramp gate... . a ford 8n may fall thru the e-m deck. other has wood deck.. heavy ramps. weighs more.
go figure. :)
   / hauling a 8,000lb tractor #10
There is a similar thread going around right now from a guy with a Dodge Dakota trying to figure it all out. I'll make this short; go to a reliable trailer dealer and have them run the numbers. They have a computer program that will take the guessing out of it.. As a CDL commercial operator you must see plenty of the tail wagging the dog PU and trailer combos. I was behind one a while back, a 1/2 or 3/4 with a GN and a track hoe behind, slight down grade, car cut him off, he slammed on the brakes. He was all over 3 lanes trying to get it straight. How he missed everybody is a miracle much less that he somehow kept it out of the ditch. When I passed he was parking it. Probably had to clean his shorts some. A reliable trailer dealer is one like mine; if the tow rig you have is inadequate they will not deliver the trailer on their premises.
Ron
24008 (A53422)
24008 (A53422)
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2015 Ford F-350 Service Truck (A55852)
2015 Ford F-350...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
