Broken Controls Koyker 160 FEL
   / Broken Controls Koyker 160 FEL
Sorry. Got wrong picture on the last post I made. Here are a couple of the welded spool. It seems to work so far. No leaks yet.
   / Broken Controls Koyker 160 FEL #12
Good deal, and keep those joints lubed.
Thank you everybody for the info and help.
   / Broken Controls Koyker 160 FEL #14
Jimmy;
I read your post on this forum, while searching for a supplier for replacement spools for a Dinoil Hydraulic valve body. I own a Machine shop here in Anderson, IN. A customer brought in to my shop the exact same Dinoil valve body, that you show in your posting. After learning there was no one offering replacement spools, I decided to devise a way to repair their spool without welding. I have drawings, and instructions on how to repair the spools, but don't know how to post them. It seams as though this is a constant problem, but can be easly fixed if you have access to a local machine shop. I will share them with anyone who has this problem. Jim Watters, Watters Custom Machine & Engineering, 878 N. 200 E., Anderson, IN. 46012. 765-278-4060. email watterscme@gmail.com. Thank you. Jim Watters
   / Broken Controls Koyker 160 FEL #15
If you can scan them, you can post them.
I am curious how one can fix a worn spool and bore in a valve.
I would be interested in how you do this.
Jim
All the post before yours are from 2010
   / Broken Controls Koyker 160 FEL #16
Jim
J. J., here is the drawing depicting the method I used to repair a Dinoil spool valve. It didn't take very long, and works very well. A lot less expensive than a new valve-body, which is all the dealer offered me.
   / Broken Controls Koyker 160 FEL #17
No drawing was displayed. Try again.
Jim... If you can email me the files to me I can go ahead and attach them for you. My email address is jimmypowell@raker.com.
Thanks,
Jimmy
BTW the welded spool is still holding up pretty good.
   / Broken Controls Koyker 160 FEL #20
I repaired a worn spool/housing back in the late 60's by having the spool built up with hard chrome and then grinding the spool lands to a slight oversize. (cylindrical grinder) Then honed the valve body for a slip fit on the spool. Probably wouldn't be cost effective given today's economy, however.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
