For those of you who think the L3400 has a weak loader!!
   / For those of you who think the L3400 has a weak loader!! #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Moving some dirt today. It amazes me the number of times I hear people mention that the L3400 (2800/3200/3400/3700/3800) have weak loaders.
Who needs more lift on a CUT??? Mine has never failed to lift anything I have tried.
I have a 700lb blade on the back and loaded tires for ballast. And even this load was tippy under the right circumstances (downhill or stopping).
the last picture I made sure to include the pressure gauge. It takes 500PSI just to lift the loader frame and empty bucket. I have 2500PSI to play with. So at 2000PSI, this load is only 3/4 of what I "can" lift. And bota lists my bucket at 8.1 cu ft struck capacity. So I'd venture to say I had darn near half a yard on there (13.5 cu ft)
I certainly dont know what I would do with a spec of double what mine is rated for. It would be usless to me except for bragging rights.
Certainly not a weak loader by any means. Just might not have a "bragging rights" spec.
   / For those of you who think the L3400 has a weak loader!! #2
Nice point made, I like the gauge, is that a permanent mount? Does the gauge fluctuate when picking up different loads based on weight?
   / For those of you who think the L3400 has a weak loader!! #3
View attachment 334078View attachment 334079View attachment 334080
I never at any time though my L3400hst had a weak loader. I thought mine would lift more than the spec.. I can't prove that, and It would be a bit difficult now, as I don't have it any more, but I lifted some rocks that most people would not believe it would lift. My Kioti is stronger, and its bucket is bigger, but not a whole lot stronger, maybe 200-300 lbs.
James K0UA
   / For those of you who think the L3400 has a weak loader!! #4
I'm in the " I think the loader is weak camp" I may be unfairly comparing it to what I'm used to lifting with my Skidsteer. I know it is far weaker than that but I still remember not being able to lift my empty sander out of the back of the dump truck....that sucked.
ITs mounted with a quick connect and a tee. I leave it on the lift circuit, but the way I made it, I can hook it up to any of the 4 functions. Or I can remove the tee completely, and hook the gauge direct to any port.
Skidsteers will always be stronger than tractors. Thats what they are made to do...lift. A small SS can lift as much as a 60 or 70HP tractor that is physically about 3x's bigger.
As to the not lifting the sander out, what did you have on the back for ballast?? Cause with my loaded tires and 700# rear blade, I have enough power to lift the rear of the tractor. and with my 1100# 6' bushhog, Using a combination of curl and lift, I can do the same. IF you were lifting the rear of your tractor, that dont mean you have a week loader by any means.
James K0UA
Yep, it is quite an impressive little tractor (short of the jerky hitch :laughing:)
One would "assume" the loader is underrated. But the geometry of the loader, they can lift ALOT more down low. The kubota loader manual shows the curved graph. According to it, the LA460 can lift ~800kg to a height of 500mm before it starts to drop off. I still think it is a tad underrated, but the whole point of this thread is to not get hung up on specs. I can lift a heaped bucket load of dirt as high as it will go. What more do I need?? Its not a forklift. And any loader that "specs" stronger on a tractor under 3000# is a waste IMO. Cause as I mentioned, loaded tires and an 1100# bushhog hanging way back, and I can still be tipsy. Not sure what the COG and weight of the backhoe for this tractor weigh, but I'd guess it dont offer much more for ballast than my hog...
   / For those of you who think the L3400 has a weak loader!! #7
I had the BH on it. I had to reach into the bed of the truck with a set of forks on the QA ( I'm guessing they weigh 300lbs) Cat brand and very stout. Looped a chain around the forks and hooked to the sander ( 800 lbs ( I'm guessing) and no dice. It stopped lifting and did not have the sack to curl either.
   / For those of you who think the L3400 has a weak loader!! #8
Good points, I had my "rears in the air " by lifting huge rocks too, even with my 750 lbs ballast barrel on the back. I never lifted the rears after I filled the tires and had the ballast barrel on too. But then again I never tried that same rock again either.:shocked:
   / For those of you who think the L3400 has a weak loader!! #9
I'm with ya LD1. The lift capacity of my L3800 has really impressed me! Never failed to left anything I needed.
If one needs more, just get a larger tractor! :cool:
   / For those of you who think the L3400 has a weak loader!! #10
   / For those of you who think the L3400 has a weak loader!! #11
Ya know, read stuff here for awhile and you start to think you 'need' a larger tractor. My wife got so tired of me talking about larger tractors 6 months ago, she said "just go get an bigger one". But I didn't want to spend the money and the L3800 always does everything I need.
The L3400/3800 is a lot larger than any of the BX or B models ya know. :laughing:
   / For those of you who think the L3400 has a weak loader!! #12
I certainly don't know what I would do with a spec of double what mine is rated for. It would be usless to me except for bragging rights.
"In my experience you'd find plenty especially with pallet forks"
Loader Lift capacity is like barn capacity in the fact that with a barn the crap will expand to fill the space. Similarly with a loader the greater capacity the heavier stuff you will attempt to pick up. Obects you would pass at I lift without thinking about. Back to the pole barn analogy My dads pole barn 40' x30' Full (I'm storing his excess crap in my barns), My 56x32 & 40x24 barns are approaching capacity which is why i had to get the Saturn out. Neighbors 40x60 almost full just enough room to juggle stuff around inside.
Loader capacity is also a lot like going from VGA to HD TV you don't really appreciate the HD TV until you've had it, and once you have you don't want to go back
The CUT's definitely serve their purpose and they definitely make a lot of people happy. I'm very glad yours is sized to your needs. I really would not mind having a 40 hp Cab CUT with loader someday. However I was really concerned with lift capacity not just for bragging rights, but because I've used CUT's like a Kubota L3130 or B3030 and JD SCUT 2520 and yes they could do work but not at the pace i wanted. nor would they lift the kind of load i wanted. I do a fair amount of wood work mostly Firewood and some mill work and when you can avoid having to use the 3pt and just use the loader you can save an awe full lot of time when using pallet forks.
When i Ordered 31 squares of shingles and had the lowes delivery guy told me that it is not possible to get them out to my barn due to the off camber hill and slight ditch at the road, he clamed he'd get stuck, it was really nice being able to tell him fine leave them at the road i'll move them my self. having the ability to lift a 2600 lb pallet and carrry it 125 yards to the barn was really nice I hauled this giant piece of swamp oak out of the swamp and onto the wood mizer because his lift could not get it. "There is a stuck tractor story associated with this log"
Here are a few examples of why i needed more lift capacity
My buddies Barn yep its full too :D
Some of the Ash we cut that day
   / For those of you who think the L3400 has a weak loader!! #13
LD1,
It sounds like your loader and tractor are well matched for the uses you have it for :thumbsup: Not all of us can say that. :laughing: That's the beauty of all the choices we have, if you don't need a lot of lift capacity, you can get away with a smaller loader like yours, if you do need a lot, you just buy a loader/tractor that matches your needs. Sounds like you hit the perfect match!
I also agree with you that these small tractors really can lift a lot of weight, and do a really lot of work. I've never once found myself needing more lift capacity when it comes to moving dirt. However, pretty often I max out my lift capacity with a larger loader than you have. So I guess it just depends on what your needs are. I think for the most part, and in most people's situations, you can get away with the smaller loaders of CUT's.
I"m with you Dave, I could certainly use more loader lift capacity.
There are times though, when I just haven't been able to lift the logs I'm trying to get to my mill, that is really when I wish for more lift capacity. I hate it when I try to lift a log only to realize I can't, then I have to go back to where the equipment is parked, start up the JD 410, get the chains for the bucket, go back to the log, chain it up, and carry it to the mill. It would be a lot nicer to just be able to lift the logs I handle on a regular basis with the tractor I use on a regular basis. So you can put me in the "need more loader lift capacity" camp :laughing:
   / For those of you who think the L3400 has a weak loader!! #14
Dave, that's a 'Hog' and yes I could find some uses for it. But I'm logging in some tight places and that thing just would not fit, without cutting more trees than I want and making wider trails. Very cool machine though and could sure handle the mowing of some of our larger fields. :thumbsup:
I dont pass on anything. I just get the hoe. E41A0641.JPG Guestimate of 6-7k
The point isnt about comparing my 3400 to a 85 HP tractor and matched loader. Sure, if you need to lift a 2500lb pallet, get a bigger tractor.
But some of the tractors being marketed today, VERY similar size and HP to mine, with 2-2.5x's the lift "spec" What would one do with that. IF you believe the specs, there is no way I could lift 2.5x's more than I lift now, without anchoring the rear of the tractor to the ground. THATS my point. My loader is sufficient enough to lift the rear with my heaviest implement. So giving it an over-inflated loader rating is absolutely useless other than for bragging rights (marketing)
   / For those of you who think the L3400 has a weak loader!! #16
Thanks Yeah its large and i run into places i don't fit. We also use My buddies john deere it fits into much tighter places especially with no loader. Like i said i would love a smaller cab tractor someday but for now the M series was my best option. My Biggest drawback is the machine weight limits my ability to traverse my yard without tearing up the grass.
Definitely a tractor for every need and fortunately theirs lots to choose from so we can all get what best suits those needs. My next store neighbor loves his b2400 and has put 900 hours on it
   / For those of you who think the L3400 has a weak loader!! #17
I dont pass on anything. I just get the hoe. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=334152"/> Guestimate of 6-7k
Lol yeah that industiral works. Gotcha Yeah i have loaded tires and unless i have another 1500 lbs on the back i can do a wheel stand. Unfortunately the Kubotas tend to be lighter than the competition but probably not that much lighter if the competition really rates them that much higher.
   / For those of you who think the L3400 has a weak loader!! #18
I didn't get that you were trying to compare it to the competition on similar sized tractors
   / For those of you who think the L3400 has a weak loader!! #19
Okay, I gotcha now. I think I misunderstood what you were saying. :)
Nice pic with the huge boulder!
Here are some of the specs I am talking about...
Tractor.......................Tractor weight......................................rated lift @ pins
L3800..............................2600...................................................~1100
Mahindra 3616...................2500...................................................1650
Max28..............................1800....................................................1400:shocked:
LS G3038..........................2600....................................................1900
LS R3039..........................2700.....................................................2250
These are just a few. There are quite a few that are right on par as well. The Kioti CK35 and DS3510 are near identical spec wise. The deere 3320 is quite believable. Tractor weighs 300 more, and lifts 300 more. The Boomer 35 is like the deere 3320.
But some just seem to have really over inflated specs. I really cannot believe that the LS R3039 can lift a full 1000lbs MORE, and only weigh 100lbs more than my kubota. That is the prime example of what I am getting at. And the 3616 being a tad lighter, yet lifting 50% more.......I dont buy that for a second. Sure, it may have massive cylinders and be capable of lifting more on paper, but real world...........
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
