LD1
Epic Contributor
I have trouble seeing where adding 1000 pounds to the rear end to hold it down takes any load off the front axle but rather just keeps the rear wheels on the ground.
Simply put, there are 2 fulcrums. Both axles. ANY weight behind the rear axle, provided the rear end stays in contact, is transferring weight OFF the front axle. But as I described in my previous post, up to a point, adding rear counterweight wont lessen the load on the front. And that "point" being when the rears are still in the air. Cause you need 2 axles in contact with the ground to have 2 fulcrum points to get the counterweight effect.
