ATTN: Heavy BOX BLADE Experts.....Give us your opinions please.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #201
I'll be interested to see how the servo valves tie into the tractor hydraulics and whether they require closed center.
Right now I am considering using the third remote set to power the two Danfoss proportioning valves. Open center setup, so I will likely need a flow divider ahead of the two valves so that both can function at the same time. I was told that 6 gpm to each valve was more than enough for good response time. I will probably need to turn this circuit off to use the other two circuits but I can live with that. Most adjustment to the tongue should be infrequent and should be true for the scarifiers too.
If I did enough of this work in good weather I could see using an older 3020 or 4020 tricycle tractor with closed center hydraulics. Two wheel drive would be more appropriate where you are making lots of turns. The ground I would be using this for is almost flat bottom land so slopes are not an issue with the narrow fronts, being able to turn tight enough to stay between the borders (terraces) is important.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #202
How about a high crop tricycle tractor with your box blade belly mounted?
Sure would be easy to see the blade!
Farmall 340 High Crop.jpg Farmall 340-High Crop.jpg frontends_highcrop.jpg JD-LP-HC-430.jpg
Pictures from Google Image Search. Not mine.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #203
Nice old tractors you have. I remember seeing a stretch high crop tractor somewhere on the net too.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #204
I'm guessing the two Danfoss proportioning valves are open center type? The reason I'm asking is otherwise the pump flow would have to go over the system relief valve most of the time.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #205
Yes the SD valves are open center, you can set this system up with either open or closed centers. Both of my current tractors and a new 5xxx tractor would all be open center hydraulic systems. I am planning on having a relief valve for these two valves and will set it a 200 psi above what is needed once I test the system.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #206
What happened to the beast build project? Did I miss the video?
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #207
Ford850
I suspect EA will post a video when they can get to it.
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #208
They've been busy documenting what the underside of a white kioti looks like while laying on its side :) and showing improvements that they've made to their implements
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #209
As what typically happens, the thread has been hijacked/deviated/punctured/altered/split.....:laughing:
No offense guys, but with all the interest in the wheeled boxes and related hydraulics perhaps a separate thread is in order? Just sayin....
   / ATTN: Heavy BOX BLADE Experts.....Give us your opinions please. #210
I agree I keep seeing updates to this thread hoping for more info on the beast but its just more unrelated stuff each time.
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
