Changed fuel injection pump oil and now Ford 1700 will only idle
   / Changed fuel injection pump oil and now Ford 1700 will only idle #11
Perfectly great explanation (story). You are da man on the 1700s. Been reading your posts for a while and you know your stuff. Hope the OP gets it figured out and lets us know the outcome.
I'm making it up as I go:)
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #12
I worked on it some more this morning. I took both injectors apart and they looked good. I then cranked the engine over without the injectors and got steady fuel pulses on both lines. Put everything back together and same thing. It starts right up, but only idles at 650 (cycles from 600 to 700 at a steady rhythm). I let it run for about 10 minutes. I'm now able to loosen either injector line and get fuel streaming out without the engine dying.
I of course started by adding another 1.5 oz of oil, to bring the total to 2 oz.
Throttle attachment should be fine since the engine shuts down when the hand throttle is pushed all the way forward. I'll double check the linkage just to make sure.
There is a governor assembly behind the plate as shown below. I wonderd if the spring on the cover is not put right and causing issue with it. when you use the hand crank or foot crank can you then fully see complete movement of the linkage rod left or right on the injector pump? I'd put a witness mark on the adjustment and adjust it up to see if it make any difference, really you should not have to do that just by changing oil in the injector pump.
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #13
Can you push the hand throttle all the way down (backward) and observe full forward movement of lever on the injector?
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #14
Another crazy idea Peter, Did you put in the filter medial right? upside down ? may be? could it limit the fuel delivery to no more than Idle? is you tank shut off valve fully open? I'd take the hose downstream of the valve off, put a cup under and open the valve to see if I get good flow of fuel by gravity. I had in one occasion the same situation as I could not go above idle, had plenty of fuel and did not do anything with filter and injector. What happened was that a small piece of rubber from cap cover the outlet fuel pipe from the tank. This happened after a bumpy ride and sloshing the fuel around in the tank. When i took the rubber hose of I pushed some compressed air and there it cam fuel in full force. I got it to work and later I flushed the tank and cleaned it well. So far I have not had the same issue.
JC,
Looked at it some more this afternoon. Popped the fuel line where it enters the pump, and I have full flow there. I then observed that I had full motion of the lever on the pump, and I did.
I then removed the fuel filter and started removing all the bolts from the cover to pull it off. As I started removing the last bolt, I heard this sound like a spring returning to where it should be. So rather than completely removing the plate, I put the rest of the bolts back on, re-attached the fuel filter, bleed the system again, and started it back up. Full rpm range control once again!
So apparently, just pulling that plate back 1/8" or so (with all the bolts still attached), was enough to cause that spring, or whatever it was, to get out of place. I'll be sure to keep that in mind the next time I change the oil.
   / Changed fuel injection pump oil and now Ford 1700 will only idle #16
Nice, Success at last:thumbsup:
Now my suggestion is since you don not have the drain hole then why don't you make one. Next time carefully take a plate off drill, tap and put a Brand new drain hole for future use. You can drill and tap a new drain point i the side where the casting shows a location for a drain hole. I'm puzzled why they have no done so. Maybe they made your like late Friday afternoon on the last shift. At any rate you can reproduce what you have done here and knowing 2 oz of oil is all you need to know going from here forward.
JC,
That's a good idea JC. I'll do that. I'll order a new plate gasket as well, since the current one is a little messed up from prying the plate from the housing. With the plate off, I can stick a rag in there to ensure no cuttings remain behind.
   / Changed fuel injection pump oil and now Ford 1700 will only idle #18
Nice, That ought to do it and you really don't need a level hole either. rag is good idea and plus with the plate out you can do a visual inspection too.
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #19
Great news! Told ya JC was da 1700 man. His previous posts and pictures helped me change my lift piston O-ring on my 1500, the 1700's little brother.
   / Changed fuel injection pump oil and now Ford 1700 will only idle #20
Thanks. I'm indeed glad my posts helped you out. That's great, good for ya :thumbsup:. These little tractor don't have many bells and whistles but are built to last with knowledge (not much of it) and a pinch of TLC.
JC,:)
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2011 Ford F-250 Pickup Truck, VIN # 1FT7W2BT3BEC34199 (A51572)
2011 Ford F-250...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
