ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
The point is not to load the FEL without weight on the 3 pt hitch. Occasionally might be OK, but do it a lot and you will kill the front axle components
I must respectfully disagree with this statement Don.
I imagine the engineers designed into the tractor it's successful ability to carry all the FEL has the ability to lift. I can't imagine them not doing that. That's the reason for different sized loaders on different sized tractors. I also imagine they designed a margin of error to allow for operators like us that cheat to get more lift.
I use a Grapple bucket 90% of the time. That adds a significant amount of additional stress to the loader and tractor because of how you can cheat in lifting loads. I.e., grab a heavy load and roll the bucket fully back to get the load closer to the loader frame before trying to pick it up.
I work my FEL hard. I rarely carry enough 3pt ballast to offset the load on my front axle. Yes, my front axle components will wear out quicker than someone that does not have an FEL. No different than someone's 4wd truck wearing quicker if they use it a lot compared to an owner that never puts his in 4wd.
Use ballast weight for safety and stability and only as needed.
