There are two fulcrum points at play. The front axle and the rear. Which fulcrum you use in your calculations depends on what you are trying to find out.
The load of hay on the FEL spear is using the front axle as a fulcrum. All that weight hanging forward of the front axle is like a big lever trying to lift everything behind it.
A load on the 3PH bale spear uses the rear axle as the fulcrum, and tries to unload everything forward of that, as you demonstrated.
But all the weight in the world directly over the fulcrum does nothing fore and aft of the fulcrum. If the goal is to lighten everything forward of the rear axle (like the front axle), the weight HAS to be behind the fulcrum (rear axle).
Picture this simple lever. Like a teeter totter. The fulcrum (middle of the teeter totter) is the rear axle. The goal is to reduce weight on one side of the teeter totter. You can put 100lbs or 1000lbs directly over the pivot (rear axle) and it wont effect the weight on either side right??? The only way to effect one side is to add weight to the other. So adding 1000lbs of liquid tire ballast will only add 1000lbs to the rear and nothing else.
No need to load the tires to test. If you want to make a trip back to the scales, you dont even need any hay. Just take a couple of hefty buddies. When sitting with the front axle only on the scales, make note of the weight. Now have them buddies stand on the tires right in the middle and see that there is no change of front axle loading.
Now a bit sideracked, I mentioned in the
L3400 thread, that up to a point, adding weight, even behind the rear axle, "can" add more weight to the front axle. Lets use your 7700# tractor as an example. Lets say you can only lift 1500# before the rear tires leave the ground. Now your front axle is carrying the entire 7700+1500lbs. Thats 9200lbs. Now you add a 600lb rear blade. And now you can lift 2000lbs up front but can still raise the rear tires. So now the entire 7700 tractor + 2000lb load + 600lb blade are ALL on the front axle. Thats 10,300lbs now.
The the key is to use enough ballast that the rear axle REMAINS the fulcrum point, cause when its in the air, it isnt the fulcrum. And all the weight you added in the tires OR behind it, is now all on the front axle.
Clear as mud right:thumbsup:
