Buying Advice Mahindra 4035 HST vs. Kubota L4240 HST
   / Mahindra 4035 HST vs. Kubota L4240 HST #101
R1's and R4's are usually different size so the ratio will be wrong for 4WD.
There is a fair amount of wiggle room there to account for uneven wear, tire pressure differences, etc, but it shouldn't be too hard to get R4s in the correct overall diameter.
   / Mahindra 4035 HST vs. Kubota L4240 HST #102
Mixed front and back can be done, my father in law had turfs on the rear and ag on the front when he bought a new tractor, but he had the dealer do it to match the gearing ratio, we ran it that way for several years then went with industrial on the front and turf on the back, last year I moved it to our flatland farm and we put industrial tires all the way around, it is a 1986 with never any problems, you just have to pick the right tires.
Love the chrono sign in the background :)
   / Mahindra 4035 HST vs. Kubota L4240 HST #103
My sons use to operate a paint ball field up there and some people would bring in some really scary stuff if they didn't check them.
   / Mahindra 4035 HST vs. Kubota L4240 HST #104
If you're thinking of getting R1 tires you can get R1W tires for the front that are wider and will handle heavy loads better but still offer the R1 traction. When my R1 tires need replacing that's what I'm planning on doing.
   / Mahindra 4035 HST vs. Kubota L4240 HST #105
I was talking about factory spec R1's and R4's.
You can also get a R4 tire with a R1 tread.
   / Mahindra 4035 HST vs. Kubota L4240 HST #106
I believe it!
All: I drove both tractors again today. I'll soon post a list of the advantages each tractor has, in my opinion, over the other. Until then, I have two questions. #1: About how much weight would filling the rear tires with antifreeze add to the tractor? #2: Does any other tractor mfr. offer an auto throttle control like that of the Kubota?
   / Mahindra 4035 HST vs. Kubota L4240 HST #108
On the Mahindra 4035, the rear AGs hold almost 400# of fluid each when filled to capacity.
   / Mahindra 4035 HST vs. Kubota L4240 HST #109
Yes, similar, but I think that Kubota's HST+ does more than just raise the throttle level. Not sure, just my impression. I believe that JD and one or maybe even 2 of the Korean manufacturers have the throttle advance linked to the HST pedal-s. :confused3: And just like Kubota, it is only on or available on some of the tractors, not all of them. :(
   / Mahindra 4035 HST vs. Kubota L4240 HST #110
John Deere has the eHydro on some of their models: Maximize productivity with an eHydro™ transmission
As mentioned by MtnViewRanch some others may have some of the features, I just don't know.
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A52707)
2017 GENIE GTH-844...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2019 Chevrolet Equinox AWD SUV (A55853)
2019 Chevrolet...
