wood furnace capacity
   / wood furnace capacity #21
By knowing the firebox size, it would give me an idea of the burn time. I agree the burn box looks irregular and 7 sided in that picture. If you scroll through the specification images, you find a photo that is more hexagonal. Plus the rep said it was shaped like a "stretched stop sign" 18" high….18" wide
Looks like a heptagon to me.
Ken
   / wood furnace capacity #22
OK, let's do it the simple way.
Fill the firebox full of water and then pour the water into 1 cu. ft. boxes.
OR...fill gallon jugs with the water. 1 gallon = 8.35 lbs, 1 cu. ft. water = 62.4 lbs. So about 7.5 gallons = 1 cu. ft.
See how simple it is. :drink: :cool2:
   / wood furnace capacity #23
Really though, if LD1's picture is correct, just figure the volume of a rectangular prism. Fudge a little wider on the bottom so the rectangle fits the end with a little over in some areas and a little under in others. Then it is just L x W x H. That will be plenty close enough.
There are so many other variables as to type of wood, dryness, draft, etc. that the burn rate and btu output will only be a gross approximation at best.
When you've burn't wood for 37 years and its all been a variety of oak and crappy maple, you can get a pretty good idea. What will be interesting is the different draft parameters with the new chimney with 6" diameter metal pipe and insulated as opposed to the old 7x11 clay tile uninsulated. Heat for heat i'm hoping the furnace will out heat the hooded/ducted wood stove with the same amount of wood. Doesn't seem to be a whole lot of user info on this particular furnace.
   / wood furnace capacity #25
Are each of the seven sides the same size, and just have different angles? If so, and if you can measure from top to bottom at the highest point, and from side to side at the widest point, you can figure it without the angles.
But if each side is 9" and it is 18" at the widest point, you can divide the bottom into two triangles and a rectangle. You have a 9" side and a 4.5" side to the triangles. To get the third side you use A squared + B squared = C squared. Or in this case 81= ??+20.25. So the third side is the square root of 60.75, or 7.7942288. We will round that off to 7.8" since we are talking firewood here.
Then you use Area = 1/2 X Base X Height. That is 1/2 X 7.8 X 4.5 = 17.55 square". There are two of these triangles, plus a 9" X 7.8" rectangle {70.2 square"} So the area of the bottom half is 105.3 square". Just multiply that by the depth and you will have just under half of the volume. Simple.
   / wood furnace capacity #26
It doesn't matter , the firebox is way too small for any house north of Florida. You can build a small fire in a big furnace but you can't build a big fire in a small one.
Well LD thanks for doing the math. If I continue I get 1.3 cu ft with these figures and if I double it I get 2.6. There must be another cu ft someplace.
I know. These stove and furnace companies can get mighty loose on their specifications as far as heat output capacity. I think they tabulate from a house in South Carolina some place. Allegedly this particular furnace puts out more captured heat than from their over 4 cu ft furnace that does not have this technology. I guess the proof is in the pudding.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
