Are each of the seven sides the same size, and just have different angles? If so, and if you can measure from top to bottom at the highest point, and from side to side at the widest point, you can figure it without the angles.
But if each side is 9" and it is 18" at the widest point, you can divide the bottom into two triangles and a rectangle. You have a 9" side and a 4.5" side to the triangles. To get the third side you use A squared + B squared = C squared. Or in this case 81= ??+20.25. So the third side is the square root of 60.75, or 7.7942288. We will round that off to 7.8" since we are talking firewood here.
Then you use Area = 1/2 X Base X Height. That is 1/2 X 7.8 X 4.5 = 17.55 square". There are two of these triangles, plus a 9" X 7.8" rectangle {70.2 square"} So the area of the bottom half is 105.3 square". Just multiply that by the depth and you will have just under half of the volume. Simple.
