best post hole digger for less than $1000
   / best post hole digger for less than $1000 #1
mikyt2
OH
JD
Have JD 3520. Looking for best PHD for under $1000. Thanks
   / best post hole digger for less than $1000 #3
OR browse used ones on craigslist.
   / best post hole digger for less than $1000 #4
No such thing. Once you use a loader mounted hydraulic driven PHD. You won't go back to the pto powered 3pt hitch units.
Down pressure, ability to back out of jams and no shear pins .
   / best post hole digger for less than $1000 #5
No doubt a hydraulic one is way better. But one size does not fit all. Nothing wrong with saving some $$$ and putting it towards implements that get used more
   / best post hole digger for less than $1000 #6
Good point if you are on a budget. Having said that, once you use a hydraulic FEL mount auger, it makes digging the hole almost inconsequential. When I figure my time I will need to set a post, I don't even factor digging the hole. It is maybe a minute. And like was mentioned, you can back out from under rocks and roots rather than fight with a stuck auger.
   / best post hole digger for less than $1000 #7
But if you don't have enough money, a PTO digger is 10x's better than by hand
   / best post hole digger for less than $1000 #8
I've been trying that, too. Used ones are usually $500-$900, made from old car parts, or 100+ miles away.
Bruce
   / best post hole digger for less than $1000 #9
Very true. I dread digging holes by hand.
Years ago, I never thought much about it and would put in 1000s of feet of fence using wood posts with nothing but a shovel. Prior to that, my grandpa used to pound them in with a sledgehammer while standing on the hay trailer. But back in those days they had a bunkhouse and crew to do what I do part time by myself and a few tractors.
   / best post hole digger for less than $1000 #10
Bruce
I did that for about three years, finally bought one with two augers at Agrisupply.
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2013 E-One 95FT Ladder Fire Truck (A51692)
2013 E-One 95FT...
2008 Lincoln Electric Ranger 250GXT Trailer-Mounted Welder (A51691)
2008 Lincoln...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
