best post hole digger for less than $1000
   / best post hole digger for less than $1000 #1
mikyt2
OH
JD
Have JD 3520. Looking for best PHD for under $1000. Thanks
   / best post hole digger for less than $1000 #3
OR browse used ones on craigslist.
   / best post hole digger for less than $1000 #4
No such thing. Once you use a loader mounted hydraulic driven PHD. You won't go back to the pto powered 3pt hitch units.
Down pressure, ability to back out of jams and no shear pins .
   / best post hole digger for less than $1000 #5
No doubt a hydraulic one is way better. But one size does not fit all. Nothing wrong with saving some $$$ and putting it towards implements that get used more
   / best post hole digger for less than $1000 #6
Good point if you are on a budget. Having said that, once you use a hydraulic FEL mount auger, it makes digging the hole almost inconsequential. When I figure my time I will need to set a post, I don't even factor digging the hole. It is maybe a minute. And like was mentioned, you can back out from under rocks and roots rather than fight with a stuck auger.
   / best post hole digger for less than $1000 #7
But if you don't have enough money, a PTO digger is 10x's better than by hand
   / best post hole digger for less than $1000 #8
I've been trying that, too. Used ones are usually $500-$900, made from old car parts, or 100+ miles away.
Bruce
   / best post hole digger for less than $1000 #9
Very true. I dread digging holes by hand.
Years ago, I never thought much about it and would put in 1000s of feet of fence using wood posts with nothing but a shovel. Prior to that, my grandpa used to pound them in with a sledgehammer while standing on the hay trailer. But back in those days they had a bunkhouse and crew to do what I do part time by myself and a few tractors.
   / best post hole digger for less than $1000 #10
Bruce
I did that for about three years, finally bought one with two augers at Agrisupply.
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2007 Deere 650J LGP (A50123)
2007 Deere 650J...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
Ford Tractor (A50120)
1999 Starcraft Starlite 22ft T/A Travel Trailer (A51694)
1999 Starcraft...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
