best post hole digger for less than $1000
   / best post hole digger for less than $1000 #21
I made my own PHD for under 1K. I think I was at 850 or so with hoses. Steel was pre-cut and pre drilled, did my own welding (not much needed)
We never saw pictures, so I guess it didn't happen!!!!!:cool:
   / best post hole digger for less than $1000 #22
Did you know Including a picture of home made equipment is an unwritten rule on TBN?
   / best post hole digger for less than $1000 #23
Never saw pictures of that unwritten rule so guess it doesn't exist.:D
   / best post hole digger for less than $1000 #24
That is why it is unwritten. But it is still a rule.
   / best post hole digger for less than $1000 #25
i got mine on CL for $250 with 9" auger
   / best post hole digger for less than $1000 #26
Should be able to find the Lienbach line of PHD for around $550 New with one auger of your choice - up to 12 inch...Bought my 7200 JR for under $500 delivered with a 12" auger (delivered to a local business) about 3 years ago...
I am guessing the price has gone up...
   / best post hole digger for less than $1000 #27
As requested. Basically come C Channel (big) and a bunch of pre drilled holes. A wheel motor with a hub. 2 plates drilled to match the wheel hub and a pipe welded on one to hold the drill. Motor came from Surplus Center. Auger was the most expensive item ($300) but I didn't want to take a risk on a cheaper auger.
   / best post hole digger for less than $1000 #28
WOW ! Nice. I did not gather that it was hydraulic based on your original post. Very good work. I see you have it so it swivels forward to back.
   / best post hole digger for less than $1000 #29
And left and right. The Tractor is rated to 45 degrees and I am planting trees on slopes so the "gimbaled" head is nice. It does have extra holes where I can run a bolt through to lock it in place.
   / best post hole digger for less than $1000 #30
Oh wow, left to right must be behind the plate? Nice machine as well. That will handle some nasty terrain for sure.
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
1990 PETERBILT 320 HYDROVAC (A53843)
1990 PETERBILT 320...
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
