5205 Dual Control Valve - Loader won't tilt bucket
   / 5205 Dual Control Valve - Loader won't tilt bucket
no go. It moves a bit and rotates easily, but doesn't disconnect. Any other ideas? The other connections up to the boom all have the same coupler.
   / 5205 Dual Control Valve - Loader won't tilt bucket #12
Try shutting the tractor off, then moving the controls in all directions a couple to times to clear any pressure in the lines before trying to take it off.
Aaron Z
Tried that as well, as you can see in the photo, not much rust around fittings, but pushing in and pulling out doesn't do anything. It only pushes in a fraction of an inch...
   / 5205 Dual Control Valve - Loader won't tilt bucket #14
If the cables(parts key #13) are dirty/rusty then relieving hyd pressure on control valve is difficult causing quick-disconnects in your photo difficult to disconnect and more difficult to reconnect
Thanks all for all of the help and suggestions. Turns out 125 pounds of me just wasn't enough to push/pull the connections out. Enlisted strong neighbor, with a couple taps of the hammer on one of the connections, we switched them out, tilted bucket back up (hooray) and can at least use the tractor while figuring out the cleaning of the control valve. Hopefully doesnt have to come to buying an 825.00 part!
   / 5205 Dual Control Valve - Loader won't tilt bucket #16
In your first post you said the lever for the bucket doesn't move back at all. I'll bet a new cable will solve your problem. Swapping the boom valve cable (at the valve) to the bucket valve would verify if its the cable.
   / 5205 Dual Control Valve - Loader won't tilt bucket #17
Sounds like he his loader connected the same way as my 5105 (same tractor as 5205 except for fuel pump). Tractor has two rear remotes operated by two levers on right side of seat. The levers operate the valves and I don't think that there are any cables.
   / 5205 Dual Control Valve - Loader won't tilt bucket #18
I'll bet there are cables from joystick to hyd valve. Look at the parts schematic I posted earlier.
There does not appear to be cables on the diagram for the dual control valve. By the way "he" is a "she" :)LVP7513________UN20JUL06 (1).gif
   / 5205 Dual Control Valve - Loader won't tilt bucket #20
Sorry but it's difficult to see ones gender and tell what options a tractor has by looking at a PC monitor.
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A55788)
2008 Featherlite...
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2002 Olympian D90P1 96kW Diesel Generator (A52377)
2002 Olympian...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
