Fluid Film
   / Fluid Film #11
Fluid Film is a Lanolin based product also. I like the Aerosol, as it is thin when it goes on and spreads by itself and then hardens up to about a soft grease like consistency.
James K0UA
Is it a Lube or a protector?
   / Fluid Film #12
Those with Kioti's that have that extra linkage on the rear of the tractor for the position control.. I spray some in there also. I use it for the telescoping sway bars, and the telescoping lower draft links too!
   / Fluid Film #13
Both.. goes on liquid, and then forms a light grease like film. Stays put. and doesn't seem to attract a lot of dirt.
   / Fluid Film #14
Have to get some. That's two I owe you.:drink:
   / Fluid Film #16
   / Fluid Film #18
A couple of years ago, Kellsport was on this board, and offered to send a free sample of the Fluid Film. So I "bit" and filled out the online form.. Well it was downhill from there as I was "hooked". as soon as the little can ran out I had to order some big ones. They are pretty smart:eek:
   / Fluid Film #20
I have some stuff called Chesterton is it the same thing?
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2018 Wacker Neuson WL 38 (A53472)
2018 Wacker Neuson...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
