Fluid Film
   / Fluid Film #11
Fluid Film is a Lanolin based product also. I like the Aerosol, as it is thin when it goes on and spreads by itself and then hardens up to about a soft grease like consistency.
James K0UA
Is it a Lube or a protector?
   / Fluid Film #12
Those with Kioti's that have that extra linkage on the rear of the tractor for the position control.. I spray some in there also. I use it for the telescoping sway bars, and the telescoping lower draft links too!
   / Fluid Film #13
Both.. goes on liquid, and then forms a light grease like film. Stays put. and doesn't seem to attract a lot of dirt.
   / Fluid Film #14
Have to get some. That's two I owe you.:drink:
   / Fluid Film #16
   / Fluid Film #18
A couple of years ago, Kellsport was on this board, and offered to send a free sample of the Fluid Film. So I "bit" and filled out the online form.. Well it was downhill from there as I was "hooked". as soon as the little can ran out I had to order some big ones. They are pretty smart:eek:
   / Fluid Film #20
I have some stuff called Chesterton is it the same thing?
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
Huskee 20 Ton Wood Splitter (A51573)
Huskee 20 Ton Wood...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
1989 Freightliner Cabover FLA086 (A53472)
1989 Freightliner...
