Gary Fowler
Super Star Member
- Joined
 - Jun 23, 2008
- Messages
 - 11,998
- Location
 - Bismarck Arkansas
- Tractor
 - 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Very nice trailer.
			Sounds good! We need pictures!Well fellas, I bought a standard 18' dovetail tandem. It has 6000lb axles, D rings all the way around, 8 ply tires, 10 ton jack, fold up heavy ramps with stands. It has brakes on both axles. It's a 1996 model but it has sat inside the previous owners trophy garage since the day he bought it. Before listing it he put the new 8ply tires on it, so no dry rot to worry about there. Brakes are good as well. No long term storage issues and it's better than new.
18' with the FEL and bush hog attached will leave me some overhang, but it's worth it for the ease of use with this new trailer.
View attachment 338394View attachment 338395View attachment 338396Here is some pics, sorry it was early AM.View attachment 338393
Nice trailer! How long is it? Do you know what it weighs empty?
Dpilot, you are most likely correct, but I have seen some tires that are load range D with a 3000lb rating
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Marathon+Radial&sidewall=Blackwall&partnum=38R6MARV2&tab=Specs
I personally dont like the B, C, D, E, ratings. Nor do I like "ply" ratings. I like to know what the tire is actually rated for # wise.
There can be a big spread withing the D or E rating. Depending on tire size and other things.
Most people dont run enough air pressure either. The Max ratings are only good at the listed air pressure. A load range D tire inflated to 50 PSI isnt much better than a C range tire
