20x10.00-10 Bar Tread
   / 20x10.00-10 Bar Tread #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Been having trouble lately with a rear tire on a Ferris IS500Z mower. Slimed it but it still keeps going down. Never cared for the traction anyway. Anyone have a source for a bar or chevron type tread in 20X10.00-10? Haven't found much on Google yet.
   / 20x10.00-10 Bar Tread #3
That won't fit.
The way to read the tire size is: Tire Diameter x Tire Width - Wheel Diameter.
You have 10" wheels, and the tires you listed are for an 8" wheel.
Here's a link to a place that has some 20x11-10 tires with a more aggressive tread. They are mostly 'knobby' type tires as opposed to tractor tread but should give you a lot better traction than standard turfs.
Discount UTV Tires ATV Tires and Wheels - Search Results for "20x11x10" - ATV UTV Tires
Being 1" wider should not pose a problem unless your tires have almost no clearance now.
Thanks for the formula & the link OB. Will check clearance for the extra width and proceed from there.
   / 20x10.00-10 Bar Tread #5
Not really "set" on the bar tread. Just heard good things about them on the forum. I haven't found them in the correct size yet anyway. I like OB's idea about an ATV/UTV tire but I think there will be clearance issues with a 20x11.
I don't see enough of a difference in tread pattern between the Carlisle Multi Trac C/S and the Carlisle Turf Masters that I currently have to warrant spending the money. This morning a search turned up these Carlisles that I ordered up:
http://www.tires-easy.com/cgi-bin/r...deep%3DR-167747&ID=froogle&wt_t=1380365498000
Well, the Carlisle ALL TRAIL II's are mounted and on the Ferris. Now all that remains is for the grass to dry enough to give them a try.
Thanks to OB for the idea of trying an ATV/UTV type tread.
   / 20x10.00-10 Bar Tread #8
They have good traction, but I hope you don't have to drive across any gravel. I have the same tread on our Ranger EV and it picks up gravel like a magnet picks up steel.
I am looking at some Interco InterForce ATV R1tires to use on it.
InterForce ATV | Interco Tire
   / 20x10.00-10 Bar Tread #9
We need an update, how do you like them?
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
Freightliner Tender Truck - Adams Tender (A53473)
Freightliner...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
