20x10.00-10 Bar Tread
   / 20x10.00-10 Bar Tread #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Been having trouble lately with a rear tire on a Ferris IS500Z mower. Slimed it but it still keeps going down. Never cared for the traction anyway. Anyone have a source for a bar or chevron type tread in 20X10.00-10? Haven't found much on Google yet.
   / 20x10.00-10 Bar Tread #3
That won't fit.
The way to read the tire size is: Tire Diameter x Tire Width - Wheel Diameter.
You have 10" wheels, and the tires you listed are for an 8" wheel.
Here's a link to a place that has some 20x11-10 tires with a more aggressive tread. They are mostly 'knobby' type tires as opposed to tractor tread but should give you a lot better traction than standard turfs.
Discount UTV Tires ATV Tires and Wheels - Search Results for "20x11x10" - ATV UTV Tires
Being 1" wider should not pose a problem unless your tires have almost no clearance now.
Thanks for the formula & the link OB. Will check clearance for the extra width and proceed from there.
   / 20x10.00-10 Bar Tread #5
Not really "set" on the bar tread. Just heard good things about them on the forum. I haven't found them in the correct size yet anyway. I like OB's idea about an ATV/UTV tire but I think there will be clearance issues with a 20x11.
I don't see enough of a difference in tread pattern between the Carlisle Multi Trac C/S and the Carlisle Turf Masters that I currently have to warrant spending the money. This morning a search turned up these Carlisles that I ordered up:
http://www.tires-easy.com/cgi-bin/r...deep%3DR-167747&ID=froogle&wt_t=1380365498000
Well, the Carlisle ALL TRAIL II's are mounted and on the Ferris. Now all that remains is for the grass to dry enough to give them a try.
Thanks to OB for the idea of trying an ATV/UTV type tread.
   / 20x10.00-10 Bar Tread #8
They have good traction, but I hope you don't have to drive across any gravel. I have the same tread on our Ranger EV and it picks up gravel like a magnet picks up steel.
I am looking at some Interco InterForce ATV R1tires to use on it.
InterForce ATV | Interco Tire
   / 20x10.00-10 Bar Tread #9
We need an update, how do you like them?
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
WB Mower (A50120)
WB Mower (A50120)
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
