Price on rear remotes
   / Price on rear remotes #31
I would consider $1900 for all 3 OEM control valves to be a fair price. Be sure to get at least 1 if not 2 of them with the float function. ;)
Thanks guys- I am going to have my dealer install 3 remotes- anything special I need to tell them??
TRACTOR JUST ARRIVED!!!! With only 100 hrs the only thing I think this guy used was the front end loader which of course is chipped- Everything else looks brand new!!!!!!
   / Price on rear remotes #33
I agree 650 a remote not to shabby.
   / Price on rear remotes #34
I would get 2 of the remotes with the float function. If you plan on using a log splitter or a wood chipper, then get the 3rd remote as a detent remote. If not, then a simple spring return to center valve for normal implement use is all that you need. ;)
   / Price on rear remotes #35
I looked at the parts breakout for the valves and it looks like the levers next to the seat are not connected directly to the valves on the GL40 (I don't know about the 60 series). It doesn't matter if it's open station or cabin. It looks like the levers have linkage that goes down to the valves. Because of this I don't know how easy it would be to use the three slots for the factory remotes if you were to try to make aftermarket valves work. I like the valves being out of sight.
I installed 3 factory remotes on my GL3240 - 2 float & 1 detent, as Brian suggested. It was wicked expensive, as others have described. But the kits are very nicely detailed to shoehorn a lot of gear into not much space at all. crazyal is right on the mark about it being a clean install and I can't imagine trying to cobble all that kit together myself. It would have been a major undertaking, spanning several days, to measure everything up, draw up a layout, fabricate, try to fit everything, curse that something isn't just right, start over again, etc, etc.
http://www.tractorbynet.com/forums/kubota-owning-operating/277057-rear-remotes-3.html
   / Price on rear remotes #37
The Kubota valve kit is very nicely made to fit design. It can be done by an amateur. Well worth the extra cost. Unless of course you like that cluttered patched together look.
   / Price on rear remotes #38
my tractor is not for looks.....its for work. but i sell a lot for looks.
   / Price on rear remotes #39
Sometimes looks also helps with functionality. A messy setup can be a headache to use with valves and hoses hung everywhere.
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
1065 (A53342)
1065 (A53342)
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
