Need advice on replacing a few boards on my trailer , oak or pine
   / Need advice on replacing a few boards on my trailer , oak or pine #1
bm3
warsaw va
MF 1635 , JD 3203 , JD 1070
The boards are oak , 5 year old skid steer trailer and already 2 rotten boards. I have older trailers that are way more used with pine deck and zero rot . Would you find oak , 14ft 2x6 , or pine . Lowes does not have oak but either way probably have to find a mill. Why would Centerville Trailers use oak anyway ? Stronger? sure rotted fast
   / Need advice on replacing a few boards on my trailer , oak or pine #2
Why not go with ground contact rated pressure treated?
I mix 50/50 motor oil and diesel to treat my deck boards.
   / Need advice on replacing a few boards on my trailer , oak or pine #3
i'd go with PT and forget the environment poisoning diesel/hazardous waste oil treatment and instead put asphalt based fence paint on them.
   / Need advice on replacing a few boards on my trailer , oak or pine #4
Any treated wood will last forever, oak or rock maple wil only add weight. go with pine
I thought pressure treated would rust the steel. Manufacturer used motor oil to treat them , guess I should have redone them. If pressure treated is ok Lowes has that in my lenght
Pine sure is easier to find for me , probably my best bet then , thanks
   / Need advice on replacing a few boards on my trailer , oak or pine #7
plenty of things better and more legal than use dmotor oil to treat wood.
I will try the asphalt based fence paint , thanks for the info
   / Need advice on replacing a few boards on my trailer , oak or pine #9
i have a flatbed i bought in 2000 it had untreated (new) lumbe ron it when i got it. didn't make it to the 2nd year before boards rotted on it. I repalced with PT pine. painted them with a-f-paint.. both sides.. liberally. then installed them.
that wood is STILL on there. about 5ys ago I put an overlay of 3/4 marine plywood on it as I was hauling a trike a few times a month, and the trike had narrow , tall rears,a nd a single front.. and depending on how i loaded.. it always put alotta weight on not enough boards.. so the 3/4 plywood really spread it out good.
agian. that same wood is showing no signs of giving up soon.
   / Need advice on replacing a few boards on my trailer , oak or pine #10
Pretty sure OAK is used for the strength. Next time I'm in there I will ask them, Centreville manufacturing is 4 miles down the road from me.
16FT BUMPER PULL SPOOL TRAILER (A55745)
16FT BUMPER PULL...
3 TON PNEUMATIC ENGINE CRANE (A55745)
3 TON PNEUMATIC...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
