Storing post hole auger?
   / Storing post hole auger? #1
Elkins45
KY
Kubota L3800
What's the best way to store a post hole auger if you don't have an equipment shed? I have to think that just leaving it sprawled out on the ground can't be good for it. Anybody have pix of a simple stand they made?
   / Storing post hole auger? #2
you just make a steel Aframe stand like a swing set frame.an make it tall enough to get the auger off the ground.
   / Storing post hole auger? #3
4x4s & some H brackets. About $20 and you would be all set. ;)
   / Storing post hole auger? #4
If you're gonna be leaving it outside, just drill a hole and unhitch n go. Doesn't cost a thing.
   / Storing post hole auger? #5
Not sure I would want the cutting tips sitting at the bottom of a muddy hole, especially if you ever wanted to change them.
   / Storing post hole auger? #6
Brian;
I assume that the horizontal member is put in place before lowering the post hole digger?
Looks like a great idea.
Rick
   / Storing post hole auger? #7
Brian;
Rick
The horizontal piece is removable and just sits in the saddles. This setup works VERY good and usually only takes about 5 minutes to get all hooked up with ZERO fighting of the implement. ;)
   / Storing post hole auger? #8
Thanks Brian, need to build this to make installation easier. Is the hydraulic cylinder for down force on auger?
Rick
   / Storing post hole auger? #9
Yes, the down pressure kit has saved me days in drilling time. ;)
   / Storing post hole auger? #10
I hang mine from a piece of chain in my equipment shed, just run the chain around the frame about a foot from the gearbox and run a small bolt through it. It hangs off of the ground and I don't have to fight it. I plan on putting up a short piece of sliding door track so I can slide it over to the side out of the way when in storage and slide it back and forth to line up with tractor,
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
Informational Lot - Shipping (A55315)
Informational Lot...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
