Storing post hole auger?
   / Storing post hole auger? #1
Elkins45
KY
Kubota L3800
What's the best way to store a post hole auger if you don't have an equipment shed? I have to think that just leaving it sprawled out on the ground can't be good for it. Anybody have pix of a simple stand they made?
   / Storing post hole auger? #2
you just make a steel Aframe stand like a swing set frame.an make it tall enough to get the auger off the ground.
   / Storing post hole auger? #3
4x4s & some H brackets. About $20 and you would be all set. ;)
   / Storing post hole auger? #4
If you're gonna be leaving it outside, just drill a hole and unhitch n go. Doesn't cost a thing.
   / Storing post hole auger? #5
Not sure I would want the cutting tips sitting at the bottom of a muddy hole, especially if you ever wanted to change them.
   / Storing post hole auger? #6
Brian;
I assume that the horizontal member is put in place before lowering the post hole digger?
Looks like a great idea.
Rick
   / Storing post hole auger? #7
Brian;
Rick
The horizontal piece is removable and just sits in the saddles. This setup works VERY good and usually only takes about 5 minutes to get all hooked up with ZERO fighting of the implement. ;)
   / Storing post hole auger? #8
Thanks Brian, need to build this to make installation easier. Is the hydraulic cylinder for down force on auger?
Rick
   / Storing post hole auger? #9
Yes, the down pressure kit has saved me days in drilling time. ;)
   / Storing post hole auger? #10
I hang mine from a piece of chain in my equipment shed, just run the chain around the frame about a foot from the gearbox and run a small bolt through it. It hangs off of the ground and I don't have to fight it. I plan on putting up a short piece of sliding door track so I can slide it over to the side out of the way when in storage and slide it back and forth to line up with tractor,
THUMB ATTACHMENT FOR MINI-EX (A55745)
THUMB ATTACHMENT...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2004 CASE 40XT SKID STEER (A52707)
2004 CASE 40XT...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
